Replacement for Nordelletronica Control panel NE152.1
Apr 27, 2025
Hi, could I just replace this panel for a newer model?
Mine is having the problem with the pressing off the symbols and it not activating.
the model I had is now discontinued and wonder if u can buy a newer version without having to have all the wiring re-done?
Sep 4, 2011
653
406
19,135
Nordelletronica were very troublesome,that is why Swift left off installing their equipement and started fitting Sargent electrical who also supply the caravan wiring system making up the wiring harnesses,ready for installation.
5,434
Apuljack have repaired and fully upgraded numerous Nordelectronica units for people on here including our good friend Parksy(Rip)
Reactions: toad a caravan
Jun 6, 2006
987
227
19,135
A bit of Fred drift
Interestingly Nordel still supply chargers etc to Adria, I think they are in other foreign vans as well
Aug 25, 2025
hi
Louby3365
Any news on your e mail to Apuljack , my control panel as started to do the same won’t switch on
5,434
hi
Louby3365
Sadly no follow up . Best you ring Apuljack direct.
I have had a new charger from them. Their own hi tech version of the BCA unit. Others have had very successful repairs done using latest technology.
did the new charger cure the on/off problem if not please could you say how you cured the problem
Regards
5,434
Regards
The Apuljack unit cured the problem with the BCA fitted to my Bailey. A friend years ago had his Norde repaired by Apuljack and all was fine at the Woosiefest. Best give them a call.
Sep 9, 2025
hi
Louby3365
Hi Louby - I have the same problem with the on/off button being temperamental and have to press multiple times to switch off. I think it needs a new control panel NE152 - did you find any replacements or advice on how to resolve the issue?
Thanks for any info.
