Replacement Kitchen Taps
I am hoping to replace a tatty loking kitchen tap with new. My system uses a pressure switch, but all the replacement taps I have found use a microswitch.
If I remove the microswitch will the taps still work, or does anyone know a supplier of non-switched taps?
Many Thanks
Brian, there is no need to remove the microswitches, just tidy the wires up so they dont catch on anything.
All the microswitch does is complete the power supply to the pump, but as your system uses the pressure system, that is not needed.
The tap will still work even with the switches not connected.
