Replacement of oil Mistakes
Sep 19, 2014
Myth one, choose expensive is the best
Excessive pursuit of brand and price, the choice is too low or too high viscous oil. For example NA car selected high viscosity oil or turbine racing car, the turbo car or driving through the area like a high turn has chosen the lowest viscosity oil. The former will be a substantial loss of engine internal power, engine internal components which will accelerate wear.
Myth, intimate blow away the remaining oil
Part technicians prefer to use air gun discharged after the oil inside the oil filler to boost the morale of the remaining oil in the engine is blown. Seemingly intimate act, in fact, counterproductive. Because the moisture in the air will follow the air gun hit the internal engine and will the newly added emulsified oil, reducing lubrication.
Myth and money to choose bargains
Use deputy factory oil filter (probably fakes) and do not replace the machine sump screws washers. Seems to be able to save some money, but in fact many of the filtering effect of non-original product is not good, there is the risk of engine damage; in addition, continue to use the original gasket, the gasket deformation aging once, it could lead to oil spills. So do not fall for picking up a pound watermelon.
Nov 19, 2010
1,542
I saw it John, but TBH so bewildered by the awful grammar that I couldn't make out whether it was spam or if I just hadn't understood it! :unsure:
However, if someone as technically literate as you says there's no sense in it, I'll give "Milerso" 24 hours to post something sensible, then I'll delete the whole thread.
