sammysoc said:
What i use on my Abbey is g3 its a cutting compound dont need alot on it goes along way,
Good luck with that then!
I'm not quite sure why these old threads are being revived, this topic is from June 2011
The advice remains the same-
DO NOT USE CUTTING COMPOUNDS ON GRP PANELS OR CARAVAN PAINTWORK
A grp panel is made up of glass reinforced plastic with a gelcoat surface finish and a cutting compound will destroy the gelcoat finish over time resulting in a dull panel with no possibility of the shine being restored. Caravan paintwork is much thinner than automotive paint and cutting compounds will soon wear it away to the base metal surface.
The best way to preserve a good shine on caravan paintwork or grp end panels is to wash the caravan with a good caravan shampoo, polish if necessary with a good car polish which is a mild cutting compound which removes stubborn marks, road film and grime ( Autoglym or Meguiars) and then wax the surface using Autoglym sealant or Meguiars stage 3 wax. The surface should be washed and waxed regularly after the initial polish and the shine will be preserved.
You don't need to polish again provided that the caravan is washed and waxed regularly and cutting paste or compounds should never be used on caravans.
There's a difference between cutting compound,which is not suitable for caravans, polish and wax,
Click Here
