Rimor Kilig 695 2025
Dec 24, 2023
16
1,515
We are about to pick up a new Rimor mid-March. The only way we can see to empty grey waste is to pull the level on the side of the motorhome. We would like to use a pipe connected to a watermaster or service pitch drain. Is there a way of doing this?
2,351
Congratulations on your purchase. I can’t help I am sorry but although this is forum is primarily populated by touring caravan users; there are a few with Mohos who may be able to advise.
2,659
Hope you enjoy your new purchase but sorry I cannot I am a caravan owner, but there are some who have a motorhome might be able help you .
Apr 23, 2024
635
511
1,135
From my limited experience with Motorhome waste systems m/homes have a waste water tank which can be emptied periodically by opening the valve is yours like that? , the ones I've come across have been metal , but some are now plastic . the metal lever types which is the empty valve usually has a internal thread on the end , probably 25mm you would need to find a suitable adapter - see 1st photo. If its plastic ( see second photo) measure the outlet diameter and go to your local hardware store and buy a length of flexible plastic pipe with fits snugly over it and lead it to the drain . If it's clear plastic hose about 13mm diameter you could then cover it in the corrugated gray tubing (28.5mm dia)( to hide any bits ) which is normally used on caravans for the waste water to service pitch drain point. It may be a bit of experimentation to get the pipe to fit the end of the drain valve and a roll of duct tape may help - please post a photo of your drain lever.
