Roll mastic sizes, which one to use?
Jan 26, 2015
91
Hi everyone,
A quick question, I want to reseal the two joints across the roof, one at the front and one at the back of my van, the sealing strip is 25mm wide so do I use 32mm bedding mastic on a roll? I'm assuming the 19mm mastic would obviously be to narrow to be effective
Simon
936
A quick answer.
Don't use roll mastic on the roof straps, use Soudall Fixall or Sikaflex 512 gunned mastic, and plenty of it.
Jan 26, 2015
91
Damian-Moderator said:
A quick answer.
Why can't or shouldn't the roll mastic be used on the roof straps, is it strength issue?
Mar 2, 2010
1,231
19,185
When ive used the roll sealer its been very stiff and didnt ouze out of the gaps,the gunned sealant seems lots softer and squashes out easily
936
Quote:
"Why can't or shouldn't the roll mastic be used on the roof straps, is it strength issue? "
Because it is the wrong thing to use in the application you describe , simple as that.
