I spoke to the salesman re this topic of running in. His reply was that the Santa Fe comes with a 5 year, unlimited mileage warranty so don't worry. Drive it as you would drive normally. Mmm, ok, not so sure.
I've researched quite a bit more since posting this thread and have found quite a bit on the subject.
I will ofcourse, as has been suggested here, look to the handbook for guidance and I believe it does say that towing should only be done once a 1000 mile period has passed.
I read that "babying" the engine will do as much harm as "hoofing" it from day one. As JTQ stated, the oil can glaze on the bore walls if the rings aren't given enough "work" to do to get them to actaully hone the bore walls on running in, just as it can when worked too hard without the oil at working temperature.
One interesting site talked of getting the oil nicely warmed up before using higher revs (2500-3500 RPM)which will help create enough pressure to expand the rings into the bore walls to help seat them properly.
It seems that changing the oil too soon also has a detrimental effect on the engine's life. Apparently the manufacturers put in a standard mineral oil to allow a certain amount of wear for this very purpose. The semi and fully synthetic oils put in at first service are much better at avoiding engine wear and so will not allow proper bedding in if changed too early.
Anyways, after all this great advice, I've arranged to try and pick the car up earlier to get some miles under my belt before our trip to Cornwall. I won't drive it like I stole it, but I will give it some work to do without labouring it. Once the 1000 miles or so are up, we'll be able to tow down to Cornwall without too much worry.
I'll let you know how we get on and what sort of performance and economy we end with.
Best wishes
Dave
