- Mar 14, 2005
- 19,063
- 4,277
- 50,935
I have written extensively about the measurement of nose weight and in particular about the importance of getting the nose height set accurately.
In the absence of a weigh-bridge the only other accurate solution has been to suggest using bathroom scales with a stick. I have always had safety reservations about this method and the strong possibility the hitch may move during measurement and force the stick out, a point that at least one other contributor has made from personal experience, so an alternative and safer method needs to be found.
Well trust the Americans, and its so obvious. I found a suggestion on an RV web site. Rather that trying to balance the stick on the scales, raise the scales on a solid support to bring them up to the right height, and rest the hitch on the scale bed. This has the added advantage of removing the weight of any stick and spreader bar from the reading the scales gives.
I recognise this is not a practical solution for when you are on your holiday, but it does give you a fairly accurate and safer measurement system for when setting out.
