satellite problem
Apr 3, 2010
when i have set up my satellite dish and my sky digi box, and have got all the channels using the sat finder. when i take off my sat finder plug the ariel back in i lose channels 1-2-3-4-5 plus a couple of others. put the sat finder back in and they are all back again.the dish does-not move at all when pluging and unplugging the sat finder. everything is set up correct & i have picked up astra 2 with a strong signal.
hope u can help keith richardson
featherstone
west yorks
Hi Keith
Look at David Sullivan's site:-
www.satelliteforcaravans.co.uk
Before you disconnect your sat finder do you get "OK" for Lock Indicator
07D4 Transport Stream
0002 Network ID?
How's the signal strength and quality?
When you reconnect do you get the above readings? Do you switch the sky box off at the mains before disconnecting the finder?
Personally I don't bother with the sat finder, a good compass has always been good enough for me.
Sorry not much help really.
Dustydog
Nov 24, 2009
53
Had same problem; leaving meter on is option, but can strain LNB connection in a wind and may get water damage.
I remade the "F" connector, slight screw in and slight shorten of centre core - worked fine! I think there was a short on one connection due to differing threaded length on male part; ooh Matron!
