Satellite Systems
May 4, 2009
21
Hi....was wondering whether to go for a satellite option for the caravan more so than trying to get a better aerial and wondered if these were recommended and how easy they were to set up.
Thanks in advance for any comments.
Dave.
Nov 27, 2009
114
We bought a "suitcase" kit from Maplin a couple of years ago.
I think it was one of their "B" grade kits and cost around
Feb 15, 2009
300
HI! Dave All you realy need is a dish and tripod to mount it .if you have a sky box in the house just use that . then as said by tony use an old whirlygig rotory dryer turned upside down get a rightangle bracket from B&Q store
5,466
Hi Dave
Forget aerials. I've been using a satellite system for the last 6 years.
Start by reading David Sullivan's brilliant site :-
www.satelliteforcaravans.co.uk/
I use a Maxview 66cm dish. tripod and quad output LNB.
We take the sky box from home.
I've never bothered with a sat finder. A decent compass guides you to 28.2 deg South East. Watch the screen sat set up. Once you are locked onto 07d4 transport stream and 0002 network ID, just fine tune by very gentle slight movement of the dish.
A dish is not instantaneous in responding to movement like an aerial , so be patient.
Try and set the angle elevation to the right mumber of degs for where you are.
When choosing a pitch I always look at the site plan first and avoid trees that may be in the way of the dish line of site.
Make sure the tripod is well anchored to the ground, sit back and enjoy.
Cheers
Dustydog
Feb 16, 2009
1,144
Dusty was looking at the the maxiview at Spinney caravans on Wednesday but the 54 centimetre dish 129.99 big difference from Discovery Leisure at 149.99, do you recommend it, it's the best one l have seen for the money, l know Aldi do them occasionally but Maxiview seem to be the company that specializes in Satellite for outdoor leisure.
Will need it when we go to Sandringham in June for 2 weeks has it has very bad tv reception
Nigel
I have never had the confidence to buy a dish and try it are we saying it is really simple to do .
I might investgoing to France for the world cup
5,466
Nigel
Have a look at Maxview's own site.
www.maxview.co.uk/.../SATELLITE_DISH_TRIPODS.html
They sell the entire kit ie dish, single LNB, tripod, compass etc for
Jul 11, 2006
490
That is a puzzling statement - '...hate Murdoch.'
Now this may seem a silly question but where do you think Freesat comes from? The only difference between Freesat (BBC/ITV) and Freesat from Sky is the EPG, plus the fact that with a once-off payment of
Jul 11, 2006
490
Jul 11, 2006
490
Jan 21, 2007
146
I bought my system from Aldi a couple of years ago and it works great. I only use the freeview channels though. I only need a compass now and have hit it first time once.
Another unintended plus is that the carry bag/case it all came in is just the right size for cabin baggage on air flights.
Apr 8, 2007
18
Sorry to jump in ,but it is related but slightly different.
I have 2 old sky boxes (as we now have HD+)one of which is Sky +, do I have to have a card or can I use any one of these without a card,
Thanks, John
Feb 16, 2009
1,144
Woody, l hates Murdock puzzling, like l hates Gordon Brown or anyone that's unfair.
I was with Sky from the early days had the whole package then l found out that those that were joining later were getting it cheaper, nothing for loyalty, then l rang up to cancel, "why Mr Heathcote", because you are giving it cheaper to new comers, "o/k we will drop yours by ex number of pounds", not good enough l say why didn't you give me the right price in the first place instead of ripping me off.
That's why l hates Murdock, ripped me off for years.
Rant over will stay with free view or free sat, anyone else got the same treatment from Sky.
NigelH
Feb 27, 2010
633
check your local yellow pages. There will be a shop / outlet selling dishes(get a sky mini dish the mesh type), LNB and tripods , and you should be able to get all that for around
Feb 16, 2009
1,144
Has any one done a demonstration Video of setting up Satellite systems, l see Maxiview has done on the Caravan Channel, the fixed system on the motorhome is good but the tripod one not quite has good.
I will be setting mine up for the first time at Easter, don't want a divorce in bag which nearly happened the first time we put the Awning up.
NigelH
Jul 11, 2006
490
DO NOT get a Sky mini-dish. They are designed to only just work in a domestic environment - that is why there is a bigger (Zone 2) dish for Scotland.
Get a conventional 60cm dish and it will work anywhere throughout and in most of France even.
Jun 14, 2009
75
I use a spare Sky box without a card as a bedroom TV connection. The only issue is that you have a limited range of channels available (you can get BBC1,2,ITV , Channel 4 and some of the other non-sky based channels)but you will need to manually connect Channel 5 and drive it through the 'services'/ 'Other Channels' button on the Sky remote.
Jeff
Jul 31, 2009
482
For what it's worth, I bought a Maplins 'satellite in a suitcase' & used it for the first time in Normandy last week without too many problems.
I fixed it using the supplied U-clamp to the jockey wheel tube.
The only problem I had was with the metal arm & disk effecting the compass, so had to hold the compass above the arm & sight it by eye.
Feb 20, 2011
17
Thanks, John
Hi
No you dont need a card as you will just get the free to air channels like free view,
But for
Apr 23, 2005
185
Like Dave I am also looking into satellite TV.
But I am only motivated by my wish to view SKY Sport.
I have my old Sky box after moving to Sky+ but without card. I have seen post re purchase of a Sky card for
Apr 7, 2008
4,909
The only way you will be able to watch sky sports is to take the box & card from home, the card will not work with any other box than the one that it is paired with.
If you put push fit 'F' connector on your sat cable in the house & the van, it will take two mins to disconnect & reconnect the cable to the back of the sat box.
If you want to watch sky+ you will have to buy a twin LNB for your portable dish.
