Hello PC
My point was to show the often held view that 'Digital instruments are always right' is flawed. I then demonstrated using supplied figures how potentially inaccurate a Sat-Nav could be, given worst case scenario.
The sad fact is we have little chance of knowing how flawed the the instrument can be at any given instance as we can's see the signals that the GPS uses.
I chose Kmph for the calculations because the quoted errors were in metric units. From understanding the maths involved, I knew that the potential error would have maximum effect at lower speeds, and to keep it within the range of real life values I chose 50Kmph which I stated was close to, not the same as 30mph.
Fundamentally GPS only produce positional fixes. The Sat-Nav software does the rest including the calculations for speed. For the reasons I gave and explained GPS has a much larger potential for error between successive position samples when travelling at low speeds. This error reduces with increasing distance moved (speed).
Your point about comparing different models of Sat Nav, simply shows they have a high level of consistency - this is not too surprising because virtually all the Sat Nav system manufactures use the same hardware decoding protocols for the GPS signals. This does not confirm or verify the accuracy of the Sat-Nav speed calculation. The greater the distance travelled between sampling points will reduce the speed calculation error this would be achieved by travelling faster or reducing the sample rate.
I do not know, but I suspect that some Sat-Navs will uses sample averaging techniques. This can reduce the effect that an single reading of maximum error has on the averaged result. So in practice the speed indication will improve its accuracy by several factors as the journey progresses.
My other point about the accuracy of the speed calculation and its display is still valid. You do not know at what point in the analogue speed the digital LSD will increment up or down. For expedience you should assume the worst case, which for drivers is that it requires you to assume that Sat-Nav reading will at least 1 count pessimistic, i.e. you are travelling at least one count faster than is indicated.
Dear John L
I just found it funny that comment on accuracy had somewhat inaccurate conversion. No slight on your intentions was meant.
My brother and I had two matching motorcycles ordered and bought together with consecutive frame numbers. The speedos read 5mph different.
This is a common fault or reality.
US military used to distort the accuracy of Sat Nav signals, that has now changed and with WAAS and EGNOS enabled units we have very good accuracy and vary fast response re data. Allthough accuracy re position is said to be around 5 metres that takes into account the actual mapping and its pictorial accuracy that is scrolling across the Sat Navs screen. With a reasonable level of Satetllite signals the sat navs probably have you on the very spot you are on most of the time even with speed you are travelling at any time as the units calculate average speed factor into its system.
Accurate testing has shown Sat Nav to be the most accurate speed calculator available to Joe Public Drivers, you can of course have a rogue unit I guess as you can have rogue speedo's even with their well known basic inaccuracy to start with.
Quote from sat nav expert re race technology timing follows. This also relates back to equipment that was using older slower processors and chipsets I understand and checked against the most accurate fixed distance timing equipment available.
"Speed errors -
Speed and position are calculated almost independently - the accuracy of speed is a completely different topic to position. Errors in speed are better defined than position - typically speed errors are in the range 0.05mph to 0.3mph. In contrast to position these errors are mainly due to errors in the GPS receiver itself (it's the carrier noise), the receiver in the DL1/AX22 has a "carrier noise" around 0.6mm which is the currently as good as it gets using today's semiconductors. I've read on other manufacturers websites speed accuracies of 0.01mph from GPS, I've no idea where they get this figure from but it is currently fundamentally impossible regardless of cost! The speed error is so low, the error can normally be neglected altogether."
This is the same sort of results found in this country, what are considered to be quite elderly sat nav units now still give the same sort of speed accuracy of modern up to date units as well.
