Security Lock Motor Mover
Aug 23, 2010
I see that there is now a security lock to lock the motor mover on to the wheel. What does everyone think, will this lead to tyre damage, or is the pressure on the tyre from the motor mover nothing to worry about?
regards Gordon
937
Mover rollers should never be left in the engaged position for long periods of time.
They should be applied to use the mover, then released.
Mar 29, 2005
25
Given that we all worry about tyres being permanantly deformed through being left standing over winter I'd have thought having the motor mover roller permanantly engaged would have caused as much if not more damage.
No proof/evidence or supplier's instructions - just common sense.
Phil
Aug 23, 2010
Thanks Phil-interesting Riversway leisure are advertising locks similar or maybe the same as corner steady locks to lock motor movers in the engaged position. Be intersting to see what the motor mover manufactures have to say.
Gordon
937
Quote " Thanks bold statements, have you got any reasoning or evidence?"
As I fit many movers, particularly for Powrtouch, I have plenty of reasons to advise what I have, otherwise I wouldnt advise it.
937
Damage to tyres, damage to roller bearings and spindles, unnecessary prolonged pressure on clamping plates causing movement of mover on chassis rail, to list a few.
Hope it helps.
Forgot to add, they are a waste of time, it only takes a few minutes to move the whole assembly away from the wheels, lock or no lock.
Dec 11, 2009
632
My thoughts exactly
1,819
The instructions with our mover said they should not be left on the wheel when not in use. I have locked them on when there have been storms and removed them after as it should prevent the van moving.
Aug 23, 2009
3,167
With the potential damage to four tyres plus potential damage to the mover I would avoid anything that involved the mover being engaged for any longer than is necessary to move the van.
