Serious Damp in the new Bailey Pageant 7 Limousin
Dec 4, 2007
233
Can the members please be of help.
New caravan, obvoius signs of damp, I have involved Mendip Caravans / Discover & Leisure to be told that I would have to pay to have the van towed back to Bristol from Tenby, should that be correct when the condition of the interior of the van is so poor that I have requested a replacement van.
Damp indicator Crystal containers, placed in the van in different locations all with showing water.
Site of cabinet to the R/H side of fridge warped to the point that the fridge door will not open.
White residue present throughout the van, told that this was normal.
Plastic container in the closet R/H side of fire, water droplets running down the said.
Fixed Bed damp, Front lounge cushions damp, front loung seats damp. Shower room door sticking, Holes discovered in flooring allowing damp into the van.
Please advise needed, first new van.
Bob
Mar 10, 2006
3,266
46
bob
until it is tested professionaly with a damp meter, you cannot claim the van is damp!
Maybe i am totally wrong.
But i believe your systoms are completly normal, i hope it is.
Crystals are certainally not an indication of damp.
Swollen wood work is a result of the wood absorbing mositure from its surroundings, some shaving may be required, but is normally nothing to get excited about.
As i have said, i hope my gut feeling is correct.
Dec 4, 2007
233
bob
Ray,
If you seen the condition in the van it would break your heart,
I shut it down the end of October and it was only by chance that I returned back to the van saturday covering a 160 mile round trip.
I lifted the front seat to find that a hole cut into the floor to allow the overflow pipe from the heater had not been sealed allowing damp into the van under the front seat.
I placed my hand above the fridge door to find a draft blowing in drom somewhere I could not find the location, but it must be behind the sink base cabinet.
With the amount of water present in the crystal containers it not damp I'm seeing its one inch of water that cannot be doing the van any good thats obvious.
Thanks for comming back mate.
Jul 4, 2006
89
Have you been ventilating the van during the winter? We have large skylight on vent and all the front windows plus shower room and one window at the back on vent. We open the cupboards and take out the contents so air can circulate.
Have you got heat on? Turn it off.
Our bailey gets signs of condensation, white spots on doors partitions, windows etc, comes off with a cloth and some polish.
Our cushions used to feel damp if left in the van all winter so we take then in now, the sponge in the cushions absorbs moisture and then releases it when the van gets warmer.
You should have holes in the floor, these are usually but not always covered with plastic grills but some of ours are open to the air, the holes are for ventilation.
Our shower room door does warp sometimes but we left it closed this year and it has been better.
All in all I'd say it's condensation, open all the windows on a dry day and let the air through, open all the cupboards and put the cushions on the ends, prop the mattress up and let the air get underneath.
I would be reluctant to pay to have the van taken back until I knew it was definitely damp.
Mar 10, 2006
3,266
46
bob
i agree with robfooty.
The air draught you describe is simply the air vent for the gas fridge, it is normal. you should have been given two plastic covers that fit over the outside vents, i have forgot to fit them once, and no problem occured.
My inboard pipe also was not sealed, it is normal. I put mastic round mine mainly to keep mice out. This is not a problem.
Holes and draughts in your van are there to vent any build up of gas, should a leak occur.
I have the electric fire on for a couple of hours during the winter to dry some of the moisture out.
Movment of air prevents condensation.
A damp expert friend of my lady told me that.
Jul 9, 2001
734
The above remidies are fine if you store at home, but for us who use storeage facilities it is much harder.
I have stored my last Bailey sealed for 3 winters and never had issues like you describe. I cannot believe you dealer is asking you to pay for the van to be taken back to the manufacturer. Remember, your contract is with the dealer not the manufacturer so in my opinion if the van has to go to the manufacturer, that is the dealer's responsibility, not your's.
G
Guest
I am terribly sorry but I have difficulty in accepting the comments mentioned. If caravans are accepted as being normal with these sorts of conditions, then I am very glad I do not own one of these types. I have never had similar problems in any of my vans, so I feel that either there is a problem, or the weather conditions where the van was stored were extreme.
Water running down a panel??
White spots everywhere??
Warped doors??
Draughts through the fridge??
These are considered normal????
Yes, mattresses and cushions can get very cold if left in the van over winter, and yes, it is a good idea to bring them indoors for a day or so before using them again. Yes, there are floor vents to allow air to circulate, but these will only introduce damp if the environment is water wet. Crystals, as mentioned will not tell you anything as they will absorb any moisture from the atmosphere, and you will be fighting a losing battle if you expect them to remain dry. Only a professional damp meter will tell you if there is a serious problem with damp in the van, and if so, then it definitely needs to be attended to under warranty.
If as mentioned, people have fridges that have not been installed properly by allowing air draughts and unsealed pipes, then I feel the dealer and manufacturer should be at least advised. Ironically the only time I had that problem was with a UK motorhome in the 1980's. With my EU vans I have never had the problem. You should also not need to add extra vents to the existing ones to stop draughts. These are only to allow the fridge to work better in cold periods by restricting the air flow EXTERNALLY.
Air should always be circulating the van as it is impossible to fully seal roof vents and the aforementioned floor vents act as conduits. If that air is very damp then yes, you may get a damp feeling inside the van, and if the sun shines then yes, you may get a bit of condensation. But it should not persist. Warping indicates to me, poor quality.
Sorry, I am not agreeing with the others, but can only tell what my experience is.
May 5, 2005
1,154
we have a bailey indiana and have not took anything out,locker doors and fridge open cushions away from walls thats it and it seems fine,cant imagine anyone spending 14k on a van and seeing water running in it as normal id be well concerned,would be worth taking it to dealers just to be on the safe side.
Feb 3, 2008
11
Heard of this before, unfortunately you bought a touring caravan, therefore under the warranty its your responsibility to take it back to your supplying dealer.
Jul 9, 2001
734
Rob
Not necessarily true, a lot of Bailey dealers offer transiant warranty so you do not have to travel to the supplying dealer if there is another closer.
Dec 14, 2006
3,205
If you really feel you have a problem can you not advise Discover Leisure/Bailey that you intend to call out a mobile Bailey approved service engineer to check the van over - and if there is a problem will expect them to foot the bill for towing back to Bristol and replacement of the van.
If there isn't a problem, and you are just seeing a problem when one doesn't exist, then it would be only fair that you paid for the inspection yourself - but at least you wouldn't have had to pay to have it towed away, only to be told that it wasn't such a problem as you imagined.
Don't just take this lying down - get a professional opinion, and if the caravan really has problems then reject it and ask for a replacement. There have been several other postings on here about panel failure on Baileys, including severe damp getting into roof panels, so you would be very well advised to sort it out sooner rather than later.
I have to say that when we bought our Swift the dealer we bought from (who would now also be Discover Leisure) were less than helpful when a serious problem developed. Because we were so concerned about the state of the axle on the van we took it to a very nearby dealership (Not a Swift dealer at the time) - who pulled out all the stops, including calling out Swift themselves. The problem was very quickly resolved thanks to the local Dealer, Swift, and Alko - so things can happen, even under warranty, without the dealer you bought from being involved.
4,267
Hi Bob
As all the others say I think it is imperative you establish asap what the problem is. A full professional damp meter test seems to be top of the list.
I have had three Baileys over the years and all stay outside uncovered when not in use. Only this week I paid her a visit and can say the seats are very cold to the touch but not "damp", no white spots etc.
May I suggest you have a word with Kelly Watts at Bailey and ask if she will organise for one their approved repairers from the list below to carry out the initial tests. It may well be you can tow the caravan to one nearest you or maybe they are mobile? I don't know. At the worst it will only cost you a few pounds to establish independently if there is a real problem that needs resolution.
As said before , just remember you Contract is with the supplying Dealer and maybe it is your responsibility to go to them. I don't know what you agreed at the point of sale.
Keep us all posted.
Cheers
Alan
Wales Retailers
AUTO-MASTER (SOUTH WALES)
LLWYNA FARM
UNIT 3 LLANHARRY ROAD
BRYSANDLER
PONTYCLUN
R.C.T.
CF72 9DB
TEL: 01443-222-234
BLAZERS CARAVAN COMPANY
ELBA CRESCENT
CRYMLYM BURROWS
FABIAN WAY
SWANSEA
WEST GLAMORGAN
SA1 8QQ
TEL: 01792 643326
FAX: 01792 650336
www.caravansinswansea.co.uk
CARAFIT CARAVAN SERVICES
BUSINESS PARK
CROSS HANDS
LLANELLI
DYFED
SA14 6RB
TEL: 01269 831215
FAX: 01269 831231
THE CARAVAN HOSPITAL
A48 ST HILARY
COWBRIDGE
VALE OF GLAMORGAN
CF71 7DP
TEL: 01446 774747
FAX: 01446 773747
CARAVAN MASTER
UNIT 2 BLOCK A
TALBOT GREEN BUSINESS PARK
PONTYCLUN
R.C.T
CF72 9FG
TEL: 01443 449973
FAX: 01443 449973
CARAVAN MEDIC
MOBILE SERVICE
SOUTH WALES
TEL: 07989-100086
FAX: 01792 892218
CONWY TOURING PARK
TREFRIW ROAD
CONWY
WALES
LL32 8UX
TEL: 01492-592856
DISCOVER WREXHAM
DUNSTER ROAD INDUSTRIAL ESTATE
WREXHAM
LL13 9RE
Tel: 01978-664300
Fax: 01978-664832
www.discover.co.uk
FLINTSHIRE CARAVANS
76 STATION ROAD
QUEENSFERRY
DEESIDE
FLINTSHIRE
CH5 2TE
Tel: 01244-830438
Fax: 01244-810352
www.flintshirecaravans.co.uk
MCSR
(MOBILE CARAVAN SERVICE REPAIR) WALES
MOBILE SERVICE
SOUTH WALES
TEL: 07816-600-686
SUNNYHAVEN CARAVAN DISTRIBUTORS
GORSEINON ROAD
PENLLERGAER
SWANSEA
WEST GLAMORGAN.
SA4 1GE
TEL: 01792 892884
FAX: 01792 899144
Dec 4, 2007
233
Thank you for your reply Bob
Dec 4, 2007
233
bob
Thank you, Bob
Dec 4, 2007
233
Thank you for your comments Bob
Dec 4, 2007
233
Warped doors??
Thank you Sir, the warping to the side closet next to the fridge was so bad that I could not open the door during the the period of time I stayed at the van 24hrs in my this laminiate was not designed to withstand such conditions.
Winter lock up.
4,267
Winter lock up.
Bob
I have to say this is not the norm.
I do hope one of the local Bailey service people can at least sort out a diagnosis. One major step in the right direction.
Cheers
Alan
Hi Bob.
Its Bailey policy as set out in the Warranty Handbook with your caravan that warranty starts at the dealership, It's your responsibility to get your caravan there. The warranty reimbursement to Dealers does not cover mileage or traveling time and the manufacturers will only start paying for warranty work done at a Dealer premisses.
It's upto any franchised non supplying dealer if they wish to carry out any warranty repairs during the first 12 months, they are not obliged to and many will not - it's best to buy localy to avoide this situation or buy localy to where you will be sitting the caravan.
Some dealers offer a mobile service others do not. Blazers & Sunnyhaven Caravans may do and they are very close to Tenby.
Make sure anyone you use is NCC registered or the manufacturer will cancell the warranty.
Ventilation is a must in caravans and all manufacturers advise the upholstery is removed when storing the caravan over the winter.
Caravans and water dont mix - get this looked at asap.
Just a point - if the Dealer who you bought the caravan from delivered it to site for you because they know you are unable to tow (unsuitable car etc)then they are duty bound in law to collect it from site and return it for warranty work or even for annual servicing.
Remember do not miss your annual service or the manufacturer will cancell the warranty - the dealer will have no say in this.
Bobby Boy
Dec 4, 2007
233
Hi Bob.
Bobby Boy
Thanks for the advise
Sep 25, 2008
133
all the symptoms described are due to a build up of condensation. this in its self is due to incorrect useage and/or storage and not a fault with the caravan.
Feb 13, 2006
80
Put a cover on it. No problem with damp then. This winter has had many extremes of temperature so condensation is possible. Ours has a cover and we haven't had a problem but then again it's a Swift!
Dec 4, 2007
233
I followed what I beleived to be the correct proceedure for laying up the van for winter, but I did not account for wind blowing into the caravan via external holes. I have should placed my van in a lock up to prevent internal damage, look up fit fot purpose, then you could be of help.
Thank you for your comments.
