Sheet straps
We have a french bed in our caravan (one corner chopped off) and have been using a normal double bed fitted sheet but it doesn't fit too well because of the shape of the bed and keeps wrinkling up becoming a bit uncomfortable in the night.
I came across someone recommending to get some sheet straps - I had never heard of them but a bit of googling and I found some and placed an order - have to say they work a treat to keep everything in place !
I got some Y shaped ones with a clip on three points which I use to pull the sheet tight on the cut off corner but also put them on the other corners for a nice secure fit.
Worth a try if you don't want to shell out for caravan specific fitted sheets as they were only around £8 for a set of 4.
Thanks Martin24, I will do that when we next buy some bedding for the van but having changed from a double bed to a king sized at home I have quite a bit of double sized bedding that we can now use comfortably.
