- Nov 11, 2009
- 24,152
- 8,500
- 50,935
While its generally true that an ICE will drive the aircon compressor, this may still have an affect on the Smart Altenator system. On my car when the Smart Alternator is in low votage output mode, turning on the Aircon makes no difference to the voltage level - its stays low.Aircon uses an engine driven compressor, so no additional electrical load, so unlikely to work.
I just load my fridge with cold stuff! Never bother switching to 12v, never had a problem, even when taking the ferry to Spain so I do seriously wonder why some folk spend all that money to address a problem that basically doesn't exist.While its generally true that an ICE will drive the aircon compressor, this may still have an affect on the Smart Altenator system. On my car when the Smart Alternator is in low votage output mode, turning on the Aircon makes no difference to the voltage level - its stays low.
However, on some implemenations people have found this to work. Most likely because the Battery Management System detects an extra load on the engine and turns up the Smart Alternator output. Some Smart Alternators typically drop into low output mode when the engine load is light - e.g coasting or breaking. Which is what mine does. But on some systems when extra load is detected the output voltage goes up.
We stop overnight in Portsmouth and switch fridge onto coldest settings. We arrive in Spain the next day and drive to Zaragoza and arrive at about 8pm. All the stuff in the freezer is still frozen. No issue.I just load my fridge with cold stuff! Never bother switching to 12v, never had a problem, even when taking the ferry to Spain so I do seriously wonder why some folk spend all that money to address a problem that basically doesn't exist.
Each to his own of course.
Which is the point I have been making!We stop overnight in Portsmouth and switch fridge onto coldest settings. We arrive in Spain the next day and drive to Zaragoza and arrive at about 8pm. All the stuff in the freezer is still frozen. No issue.
I had a chat with some other caravanners about this.Some Smart Alternators typically drop into low output mode when the engine load is light - e.g coasting or breaking. Which is what mine does. But on some systems when extra load is detected the output voltage goes up.
Are you talking wrtcthe vent covers that are required for cold weather operation?I had a chat with some other caravanners about this.
What truly is a smart alternator?
A rhetorical question but dependant on engine speed ? I don’t think is necessarily true.
More likely the voltage draw which isn’t actually connected to engine speed.
My 13 pin wiring has three out puts of relevance here.
1. Charge caravan battery
2. Live feed to ATC.
3. Feed to 12 v fridge.
Never in the last 20 years with three modern cars have I had a problem?
What is the true issue with a smart alternator? It can’t be that smart if it doesn’t recognise points 1,2 &3.
I have suspected for many years that perhaps I should remove the fridge vent covers before departure rather than on arrival🤔🤔
Yes those vents. As you know Dometic et al say the vents must be removed when the ambient temperature is above 8 degs c. Not very hot😉Are you talking wrtcthe vent covers that are required for cold weather operation?
Hyundai Santa Fe has had a smart alternator certainly since 2010, possibly since 2006.My Santa Fe manages to charge the caravan battery and keep the fridge cool whilst the car is running, none of this modern technology or smart alternators.
BUT, electronic had brake stuck on yesterday and I had to get Green flag out to get me home. 1/2 hour before they arrived I managed to release it.
Local Hyundai dealer can't get me in until 30th July.
Recall on handbrake fuse. As well.
Are you referring to removing the Vent winter covers or removing the vents themselbves.Yes those vents. As you know Dometic et al say the vents must be removed when the ambient temperature is above 8 degs c. Not very hot😉
I freely admit I travel at vastly greater temperatures with the vents in place. Am I wrong? Probably🙉
This thread is making me think we all need to reassess the situation 🤔
The winter covers per the Dometic / Bailey handbookAre you referring to removing the Vent winter covers or removing the vents themselbves.
Once cooler weather had passed I would remove the vent covers and they wouldn’t be used again until later autumn.Yes those vents. As you know Dometic et al say the vents must be removed when the ambient temperature is above 8 degs c. Not very hot😉
I keep my vent covers on while the caravan is parked at home - but avoid going away in winter!Once cooler weather had passed I would remove the vent covers and they wouldn’t be used again until later autumn.
Admittedly many decades ago Chipping Sodbury caravans said keep them fitted whilst travelling to avoid” foreign bodies” stones etc entering and damaging the fridge parts.Once cooler weather had passed I would remove the vent covers and they wouldn’t be used again until later autumn.
Subjectively I’d think nit having them fitted whilst travelling would help the fridges cooling, assuming that is that the alternator pokes out sufficient to have the fridge working. Must say I never had issues with the fridges in UK, although when going to southern france I did fit a vent fan. I also mirrored the approach followed by Hutch and Plodd.Admittedly many decades ago Chipping Sodbury caravans said keep them fitted whilst travelling to avoid” foreign bodies” stones etc entering and damaging the fridge parts.
Smart Alternators came about to improve mpg and to reduce emissions. They do so by reducing the load on the engine at certain times and allow the battery to power the onboard electrics/electronics. Then, when the battery is discharged to a certain level the Smart Alternator kicks in to recharge it. This can be done most efficiently when the vehicle is coasting or breaking - as in regenerative breaking.I had a chat with some other caravanners about this.
