Skoda coolant cold
Sep 24, 2008
925
240
19,135
Happened to look at thermostat after a fast run and was surprised it was showing zero. No warning light on either. Done visual check and could see nothing amiss. Went on Briskoda web site and it was mentioned the DSG box thermostat had problems ,plus airlocks ,pumps and all sorts of things. So went to my Skoda dealer and after three hours waiting they said its ready to pick up . I was dreading to think how much it was going to be. The fitter put it on the diagnostic m/c and found nothing wrong so bled the system and gave it a road test and it was back to normal temperature. So it came to the usual price of £60 for using said m/c.
Nov 30, 2022
1,984
1,881
2,935
I assume you meant you looked at the temperature gauge rather than the thermostat?,
9,230
Unusual to get an airlock after a car has been regularly used, so perhaps Briskoda had a point.
Jul 8, 2020
433
158
10,735
I always find this charge for Diagnostics laughable , yes the dealer diagnostics cost thousands upon thousands i understand but after all said and done its a tool required for the techs job just like a 10mm spanner . It's just another way to get money from us punters that have no choice at times . Moan over lol.
Jul 8, 2020
433
158
10,735
Sadly it’s the license + (I guess) a set minimum of X time, don’t forget a lot of main garages are over £100 + vat per hour
Yip you are so right, sadly we just need to crack on and deal with life lol.
5,339
However by the same token I would think that the same software is applied to thousands of cars so the cost per car should be a lot lower. Probably well under £100 depending on the number of units sold.
Jun 6, 2006
977
222
19,135
An auto electrician friend (independent) I think charges £50 or £60 to plug in , I know he has just bought a new package that cost an awful lot of money
5,339
By the same token if the cost is spread across a hundred or more cars, then the cost seems relevant.
Jul 8, 2020
433
158
10,735
I still feel its a tool for his job and like many techs who spend crazy cash on mac tools , snap on etc its just a tool to them at the end if the day lol
977
222
19,135
Other than if you purchase a spanner, air tool, battery tool etc its a one off payment, unlike software that can be an annual subscription
May 10, 2020
318
220
10,935
A zero reading temperature gauge is either
1) faulty sender
2) faulty gauge
3) the sender is sitting in an air pocket.
If it was an air lock around the sender then I would want to know why that situation arose. Cooling systems should vent off via the rad cap into the expansion bottle thus keeping the system full. I think I would do a little more investigating before I’d be happy.
9,230
1) faulty sender
2) faulty gauge
Thought that in my post #4.
May 10, 2020
318
220
10,935
Intresting replies to my thread,My car has now done 115k and never had that happen since new,are you getting me worried?.
No not trying to get you worried at all BUT a dicky cooling system can be a short cut to a blown head gasket. An air lock can and more likely to originate from the heater matrix. If your coolant level is consistent when cold then I wouldn’t worry too much. A tow car needs a properly functioning cooling system.
My best regards
