Sky T.V.
1,906
In South Wales there was “Rediffusion” which was a very early cable type system as there was no signal to the TV aerials. There was a switch on the windowsill that you had to twist to change channel. Only 3 channels of course.
4,579
We had Rediffusion TVs in the mid seventies. Definitely not the best Tv around at the time although it worked off a VHF or UHF aerial. No cabling in those days.
Feb 13, 2024
848
538
1,135
Was that the one's that you could rent?
2,920
Rediffusion was also in the North Staffordshire & South Manchester areas - only 2 TV channels at my Gran's in Stoke-on-Trent plus radio, BBC Home Service and Light Programme - we only had BBC TV at home
4,648
Visionhire and Radio Rentals at my parents. We shared the cost of the first 26” B&W with aerial on the top of the Telly
Aug 14, 2019
93
45
10,585
To those who record Freeveiw, which recording device do you use?
I’d love to ditch Sky but my Mrs finds it far too easy to record stuff so I can’t get shot of it!
2,920
We use a Humax Foxsat HDR Personal Video Recorder (PVR) for recording but watch live programmes on Freeview - the PVR is used both at home and comes with us in the caravan, paired with a freestanding 60cm dish.
Reactions: jimmyg352
3,881
I'm not quite sure what you mean by recording Freeview. Freeview is a steaming service, which the main channels (BBC and ITV) have agreed to support. Unless you have specialist recording gear you can't actually record it.
I have purchased BT HD recorder which can record two live TV programs at the same time. I have upgraded the HDD to an SSD which is far more responsive and physically even quieter. It has fast forward including 1minute jumps forward and 15sec backwards, so its easy to jump the adverts when playing back.
3,863
We use a Huawei Digital box to record Freeview, about £120, records 4 different channels at the same time, about 1000 hrs of recordings.
Bought from Currys.
It's a HUMAX, not Huawei
Oct 8, 2006
1,949
660
Eh? Sorry Prof but you are well wrong there.
Freeview is an over-air broadcast service that carries the five main channels and many others. Agreed some of those channels can be delivered by broadband (a.k.a. streaming) but most are through your aerial. All transmitters (of which there are nearly 1200 in the UK) carry PSB1 (BBC), PSB2 (independent main stations) and PSB3 which carries a mixture of BBC and independent stations in HD. Main stations (i.e not relays) also have Com 4, 5, and 6 carrying bucket loads of other stations but as with PSB they are ALL off air. Some main stations broadcast local TV stations on Com 7 such as Leeds TV, York TV, etc and all of them are on channel 7*. The coverage of channel 7 is very limited so there should be no mutual interference. [PSB is Public Service Broadcasting, Com n is Commercial.]
[*Confusion point 1: Com7 is a seventh transmitter on the relevant site, but Local TV is station 7 - see below.]
You are probably confused by the fact that smart TV's as well as receiving off-air can also collect stations that are fed by broadband - such as BBC iPlayer, ITXx, My5 etc. Some recorders are able to use broadband fed stations as well.
If you have a suitable recorder with a twin digital TV receiver inside them you can record two stations whilst you watch a third. Humax has always been a popular brand, but others by Panasonic and Manhattan are also very good. Some of them (notably Manhattan) can also record off broadband. All of them by default are able to record HD whether your TV has HD capability or not.
There can be some confusion with the use of the word 'channel.' In analogue days there were five TV channels, BBC1, BBC2, ITV, Channel 4 and Five. Each of these five used one signal carrier transmission or channel so there was never confusion as to what meant what.
With digital transmissions - which have one multiplex on each signal carrier channel - the programs are converted into digital data and multiplexed or computer mixed together allowing as many as eight or more programs to be available on a single signal carrier channel.
On a personal basis I refer to the signal being radiated by the transmitter site as a channel, and what I watch at home - such as BBC1/ITV2/More4 etc- as stations.
So to recap, all transmitter sites - main or relays - carry PSB1-3 which in total presents 20 stations, but in addition main stations carry Coms 4, 5, and 6 (and some Com 7) which in total will decode into around 80 or so stations. Also each of the six over-airMultiplexes (or muxes for short) have the capability to carry audio only stations - i.e. radio - which is another 24.
93
45
10,585
I wish I’d never asked. 😂😂😂😜
Thanks Woodentop but that’s all well beyond my comprehension! 😢😢
Dec 27, 2022
354
222
1,935
We had a Humax Freesat HD recording box that gave up the ghost for the second time (I replaced the HDD the first time) about 6 months ago. I replaced it with a Freeview HD recording box that so far we haven't used. We also have a 4K ROKU streaming stick and I think after this time I might just have persuaded my wife that streaming catch up is the way forward.
Good for me as nothing to take to the van (it has it's own ROKU) and no hard drive to give up the ghost.
Only downside with Freeview is that on HD you don't always get the local ITV channel. As an example we get Central South down here in Devon. SD is however local.
4,579
We use a Freesat box and can record whatever we like.
Dec 27, 2022
354
222
1,935
We have a Humax fvp-4000t 500gb freeview play tv recorder, bought from eBay.
It works but has yet to be used in anger.
2,293
11,935
No, Freeview is a terrestrial service. It is Freeview Play that streams. We have the Manhattan TR4 recorder. We previously had the TR3 and I enquired about upgrading to an SSD. Manhattan advised against it telling me that an SSD should not cope with constantly re-writing.
The Manhattan is good. But would be better with one or two more tuners.
3,881
Perhaps I did not express myself clearly enough. I was trying to differentiate between Live On Air programmes which you can record as they are broadcast, but the elements of Freeview that allow you to view programs from the last week which have to be streamed, generally you cannot record them as they are streamed, you have to download them, and then watch them. Some of the down loaded material is time limited, where live on air programs recorded do not seem to incur the time limitations.
I have no doubt you have a wide knowledge of the broadcasting system but I'm not sure why your answer needed a description of transmitters, multiplexers and relays which had no bearing on point in debate.
4,579
If they are streamed, why would anyone want to record them as they can be downloaded at any time?
2,293
11,935
However you are not recording them, you are downloading them?
It is the same thing. Though in some cases they might be encrypted.
In this way, you can download a film from say Netflix. But only the rightful account holder can play it.
Reactions: ProfJohnL
7,922
Don't some downloads have an expiry date, whereas recordings are retainable?
Oct 8, 2006
1,949
660
Still confused Prof.? Contribution #91 sort of explains it.
Freeview is an off-air terrestrial service whence you get the program through your aerial in real time.
Freeview Play allows you to see the program guide for a period (a week?) prior to the current time and date. Ergo you can 'go back' in time (OK, TV time) BUT what you watch in earlier time is fed to you by broadband. If you are at a location where you cannot get broadband of suitable quality or speed you can only watch current programs at the time and date they are broadcast, even if your TV has a Freeview Play facility. Essentially Freeview Play was an earlier form of smart TV operation - in fact you will probably find it difficult to obtain a Freeview Play TV now, such has been the rate of uptake of (so-called) smart TVs.
Hope that makes sense?
2,293
11,935
I think so, if you download from a streaming service it will only allow you to play back if conditions are met. ie, correct login details, correct device (maybe) and in date.
So if a film has expired on say Netflix, it will cease to be available for playback.
Nevertheless, the download has still been recorded. Just in a format governed by the supplier.
