small car to tow
Jun 24, 2005
I am new to caravanning and looking for a little advice. I have a 306 lxtd which can tow upto 1200kg (according to the book anyway) and am looking at buying a elddis wisp with a unladen weight of 727kg is this van suitable to be pulled by car like the 306? is it a good ratio for towing and if not what would be ok.
thanx alan
May 21, 2008
2,464
If the unladen weight is 727Kgs then your pay load is unlikely to be more than 275Kgs, which puts the van well inside the capability of your car. Being a turbo diesel it should have plenty of grunt to climb the hills.
Best way to find out is to ask for a road test. Any dealer worth his salt will accomodate especially if he thinks it'll clinch the deal.
Alan
The car weight that you need is the Kerb weight rather than the maximum towing weight.
You then need the caravan's ALW (Actual Laden Weight), which is the caravan's unladen weight + whatever payload that you add yourself (keeping this within the manufacturer's MTPLM (Maximum Technical Permissible Laden Mass)). The MTPLM will be in the caravan handbook and possibly on a plate next to the door.
The caravan's ALW shouldn't exceed 85% of the car's Kerb weight. The car's handbook should also show the maximum train weight which is the total weight of the fully laden car + fully laden caravan. The train weight shouldn't be exceeded. Also the maximum towing weight shouldn't be exceeded.
I don't know what the kerb weight of your actual car is, but I've found the weight for a 306 1.9TD on the web and it's quoted as 1080kgs. Therefore applying the 85% rule, means that your caravan ALW shouldn't exceed 918kgs. Given the caravan weight of 727kgs as you've quoted, this will allow you to carry 191kgs of your own contents. So you'll need to be careful if you want to carry an awning, gas bottles, battery, spare wheel etc + your own possessions, food sleeping bags etc. If the kerb weight is less than 1080kgs, then your allowance will be less.
I hope that you can follow this. Provided that you keep your allowance as low as possible then you should be OK.
Happy caravanning.
Jun 24, 2005
Alan
Happy caravanning.
Thanx for the info i will have a look in the morning and see where i stand..
regards
alan
