- Mar 14, 2005
- 18,950
- 4,171
- 50,935
With the drive to reduce tailpipe emissions there has been some die hard Petrol/Diesel heads who keep suggesting that Hydrogen will be saviour of big Internal combustion engines, simply by converting them to use Hydrogen gas rather than atomised liquid fuels.
For a long time Hydrogen has been recognised as one method of reducing emissions, in the case of burning it in an ICE then the output then the unwanted emissions are mainly H2O (Water) , Oil particulates needed for lubrication and heat. In fact Hydrogen fueled ICE's are no more fuel efficient than the present day Petrol or Diesel, which in practical applications rarely better than 35% meaning at least 65% of the energy content of Hydrogen will be wasted as heat.
The situation is slightly better if the hydrogen is passed through a fuel cell. the U.S. Department of Energy studies have only rated fuel cells able to achieve between 40 and 60% gas to electrical energy conversion rates.
Whilst Hydrogen is only better than traditional liquid fuels in terms of emissions , that is only part of the story. You also need to factor in the cost (financial and energy efficiency ) of producing hydrogen. The world already produces a surprising amount of hydrogen, mainly through a process called steam reforming. This process usually converts Methane to Hydrogen but as a by product it it produces about 7kg of Carbon Monoxide (CO) for every 1Kg of Hydrogen. So it's far from being ecologically good.
Then you have to consider how to store, transport and deliver the Hydrogen. One of the aspects of hydrogen is its a very small molecule, and it is avery "searching" gas which means most containment systems are unable to stop it from escaping. Estimates vary but it is rekond that 10% of all hydrogen production is lost through unavoidable leaks.
The reason I have raised this topic now is because I have come across this YouTube Vlog which shows how impractically large the storage vessels in vehicle will need to be to get near to the magic 300 mile range.
See here
See here
