- Jun 20, 2005
- 19,571
- 4,983
- 50,935
Given the wear level, it may not be economic to repair that tyreAt least it is in a repairable area.
Why would your wife be driving Dusty's car? Or did she sell the old tyre to him?My wife had one in the same spot and we ended up with a new tyre so for you i hope it repairable
It’s a 13mm bolt. Sadly too big to patch so a new tyre being fitted tomorrow. My engineer mechanic tells me the regs are very strict on hole diameter for vulcanisation.At least it is in a repairable area.
As per my #3 posted from experience when I had to buy a brand new tyre in Bangor on a Bank Holiday. Fortunately on the Forester I had fitted a full size spare otherwise given the tread depth on the three ok tyres the new full tread tyre would have been well outside Subarus specifications for tread depth uniformity across the four tyres. So the new tyre became the spare, and a part worn tyre ( the spare) became a normal road tyre, avoiding the need to replace all four tyres.It’s a 13mm bolt. Sadly too big to patch so a new tyre being fitted tomorrow. My engineer mechanic tells me the regs are very strict on hole diameter for vulcanisation.
I did wonder about tread depth. Fortunately the remaining tyres are fairly new. The disparity over a few mm shouldn’t be a problem🤞🤞As per my #3 posted from experience when I had to buy a brand new tyre in Bangor on a Bank Holiday. Fortunately on the Forester I had fitted a full size spare otherwise given the tread depth on the three ok tyres the new full tread tyre would have been well outside Subarus specifications for tread depth uniformity across the four tyres. So the new tyre became the spare, and a part worn tyre ( the spare) became a normal road tyre, avoiding the need to replace all four tyres.
Thats sounds like some cars have no differentials which would otherwise cope with variations in tyre size and rotational speed - the same as they cope with different rotational speeds when turning corners as the outer tyres have to go much further than the inner tyres.just to mention I sure your tyre person is aware.
If your driving a AWD vehicle and just changing one tyre it’s also worth checking that your vehicle AWD system is not adversely affected by different tread depts and if your not fitting then exact same tyre then the rolling diameter of the two tyres on the same axle are with in the tolerance of the AWD system some vehicles have very little tolerance and mixed tyre sizes can create a big problem? some vehicles like all 4 tyres to have similar tread depth on the same type of tyre?
The Subaru manual was very specific on allowable tread depth variations between the four tyres. I always took care to rotate the tyre positions and my full size spare was a part worn at 5mm tread depth. I figured that at 5mm it would be fine to deal with new tyres or tyres nearing the end of life at 3mm.Thats sounds like some cars have no differentials which would otherwise cope with variations in tyre size and rotational speed - the same as they cope with different rotational speeds when turning corners as the outer tyres have to go much further than the inner tyres.
Being more serious, have a look in the vehicle owners handbook - if the issue isn't referred to, then it's not relevant.
Our Freelander has a recommendation to change all 4 tyre's at the same time.Thats sounds like some cars have no differentials which would otherwise cope with variations in tyre size and rotational speed - the same as they cope with different rotational speeds when turning corners as the outer tyres have to go much further than the inner tyres.
Having new or the deepest tread pattern on the rears wheel has nothing to do with transmission "wind up" becasue even on a true 4x4 there will be a front to back differential that will easily accommodate any tread depth variations.Our Freelander has a recommendation to change all 4 tyre's at the same time.
If only replacing 2 then the new tyres MUST go on the rear or risk transmission wind-up.
That’s hearsay wrt same brand. Just a way to fleece tourists.I am a bit puzzled. Is that the tyre on the caravan or the vehicle? When we had a blow out in France, I had to fit the spare onto the caravan and the new tyre of a different make as the spare. Apparently they have a law that states that on the same axle must be the same brand and "tread" of tyre on both sides?
No idea, but was our second visit to France so did not want to take a chance. Red Pennant must have referred us to the most expensive tyre shop for miles around as tyre set us back over £100 as it was a Michelin tyre!That’s hearsay wrt same brand. Just a way to fleece tourists.
Wrt winter zones in France there was a glaring omission this months ccc magazine that extolled the benefits of driving to ski resorts. It said nothing about the need for winter tyres or snowflake rated tyres or chains. Wonder how many might get caught out.I'm not totally familiar with the tyre regulations in France, but having done a search for information, I've found no organisation stating the tyres on an axle have to be the same make, only they have to be the same type and size. The size is fairly obvious, but some sites have clarified that to mean cross-ply or radial, so essentially the same as the UK.
Where the French do deviate is about the condition of the tyre tread depth, they will condemn a tyre that has any part of its tread less than 1.6 mm deep.
In parts of France, there are defined zones where you are required to use winter rated tyres or chains during certain months.
A lot of AWD systems are front wheel drive and only send power to rear when slippage is detected. In these cases difference in thread deep between front and rear tires shouldn't matter.just to mention I sure your tyre person is aware.
