Interesting I had Michelin Climate Control on the Skoda Superb estate.
This is the logic as explained to me by Michelin at that time, around 1990. I was towing with a Citroen BX. Only 65 bhp but it went all over Europe and a great tow car in the end. But at first it was very unstable. A lot of this was due to a back heavy new caravan. This was so bad the ministry tested it and said it should not be on the road. However, strangely they did not have the power to have it taken off the road. Also the Caravan Club refused to get involved!
It came to a point that I needed new tyres, I had non premium tyres fitted and the stability improved beyond recognition.
I made the enquiry with Michelin who told me that premium tyres have supple walls in order to keep more tread on the road. But this had the result of making the rear end of the car move about a bit more both in pitch and yaw. This in turn is enlarged by the caravan and might lead towards the caravan controlling the car.
Having said that, I have used Michelin on other cars, including my present one, without any problem. But still worth bearing in mind when trying to work out why an outfit may not be as stable as you might expect.
So that again vindicates the car manufacturers. So why do people think they should modify the car when the problem is actually with something else?I 100% agree with Tuningdrew. It’s not about the suspension bottoming out or some driving beyond the outfits limits. The pitching can occur well before this and is not sufficiently controlled or dampened by the ow car.
Should assisters be fitted it is a good idea to let the insurance company know. But sometimes they need some convincing that it is for safety reasons.
It must also be considered that some tow vehicles can cope and are within limits. The problem may lie with the tyres. I once had it in writing from Michelin that they are aware that their supple walled premium tyres can induce pitching when towing. One car I had was massively improved by fitting non premium tyres. However I have used Michelin since, and do so now.
Don't "cure" the symptom, find and sort out the cause.
I’m not that sure that advice given by Michelin for a 1990 Citroen BX has a lot of bearing on today’s vehicles as in those days all French cars came out in Michelins. And Michelin didn’t make the car, but would have worked with Citroen.
Yes but advice given in 1990; how relevant is it to today’s tyres where the buyer has a far larger range of choice with most majors also making tyres that span a wider range than of yore and under different brand labels.The Michelin advice was nothing to do with Citroen nor can it be out of date. It concerns the fundamental difference between premium and non premium tyres.
I totally fail to understand your reasoning. So far I have 100% agreed with you that the tow vehicle should be mechanicallycorrect before looking as modifications.
Or, as you say, Don't "cure" the symptom, find and sort out the cause.
However, it is has been, and continually will be, that modifications specific for the job can, and do improve safety, They can make the towing experience better and with a smoother more balanced outfit must reduce wear and tear.
But if they are not needed then don’t do it, simple.
Hello John,I totally fail to understand your reasoning. So far I have 100% agreed with you that the tow vehicle should be mechanicallycorrect before looking as modifications.
Lutz, you are not correct, dampers are not shock absorbers, the dampers slow down the rate of amplitude of the rebound, the shock absorbers take the load weither they be coil springs or leaf springs. Some vehicles now have them combined in one unit with magnetic control. For the dampening rate.Spring assisters won't stop pitching. By increasing the spring rate they can only make the back end harder, thereby redung the amplitude of the pitching movement. To reduce the pitching frequency one would have to fit harder dampers (shock absorbers).
Shock absorbers are a common, but incorrect, alternative name for dampers - not sure what the combined units you're referring to unless they're "self-energising self-levelling" dampers which are fitted to some cars.Lutz, you are not correct, dampers are not shock absorbers, the dampers slow down the rate of amplitude of the rebound, the shock absorbers take the load weither they be coil springs or leaf springs. Some vehicles now have them combined in one unit with magnetic control. For the dampening rate.
My Kia Sorento had self energising self levelling system by Sach. At standstill the car when being loaded would drop slightly. Then when driven the movement of the suspension would pump up the system and level the ride height. Worked really wellShock absorbers are a common, but incorrect, alternative name for dampers - not sure what the combined units you're referring to unless they're "self-energising self-levelling" dampers which are fitted to some cars.
In the mid 1980s I worked on electro rheological fluids which would change their viscosity dependant on the electrical potential applied. These made for very rapid changes in damping characteristics and could be used in multi degree of freedom mounting raft systems for attenuating transmitted vibrations. Suitably programmed they would self adjust to suit the changes in driving frequency as the machinery varied load and speed. The major issue was that computing power and processor sizes had not quite caught up with the technology. But it has now and such dampers are installed in many applications including automotive.
Variable dynamic dampers working on the above principles are available on a number of premium models - my Touareg included it as part of the air suspension package - I generally leave it set in Comfort but when towing or on motorways I use the Sport setting.
I'm with the Prof on this one. If the car feels unsafe or uneasy when towing then it would also feel the same if the boot is fully loaded, but that is a condition that the car manufacturer should have taken into account in the design.
When someone want's to modify a vehicle it's because the vehicle doesn't do what they want it to do. Basically they have chosen the wrong vehicle.
The towing dynamics are totally different than just loading the boot. The load that requires controlling is exerting live forces which need controlling.
Agreed, the towing dynamics are somewhat different, but spring assisters are not going to solve a pitching problem. Spring assisters can only prevent the suspension bottoming out if the vehicle is regularly used at maximum rear axle load, but to prevent pitching, one has to increase the damping effect and springs don't do that.
