Hiya. What make of rubber spring assisters do people recommend for my 2015 Ford Focus please. And has anyone got any measurements of the gaps between the springs coils that I could have without me jacking my car up to measure. Thanks.
There should be no need to fit spring assisters. If you car is riding at less than the manufacturers specification, then you should be looking for the reason.Hiya. What make of rubber spring assisters do people recommend for my 2015 Ford Focus please. And has anyone got any measurements of the gaps between the springs coils that I could have without me jacking my car up to measure. Thanks.
Thanks. I was looking into advice if I did have problems with the ride height under load.I’ve used MAD spring assisters on two cars both of which had long rear overhangs but both had suspension height iaw makers specification. The SAAB 9000 CSE had no suspension sensors as it pre dated electronics. The 2014 Skoda Superb estate drove normally when fitted with MAD springs although its rear ride height increased by 12 mm. They were fitted by the Skoda main dealer who had fitted quite a number to Superb estates used fir towing caravans and trailers. Surprised though that a 2015 with short overhang might need them.
Propping up a caravan hitch on a stick is not a safe practice.I go with Prof, having towed with 3 focus models over the years. It would be worth checking the kerbweight and any max tow restriction of the car, and the max noseweight - and then measuring the nose weight of the caravan. This can be done by parking the van level and using a piece of dowel between the hitch and bathroom scales
It will either be worn suspension parts which should be replaced, or the applied load is too large, in which case you need to adjust what you are carrying. Don't forget the car has a maximum nose load value, and some manufactures boot load limits are reduced when towing. Check your manufacturer's specifications.
In addition some vehicles use suspension travel sensors to provide information to the cars stability programmes. The use of non standard suspension parts will corrupt the input data and that might make teh stability programme malfunction.
Grayston Coil Spring Assisters pair
i would not know what the measurements are sorry
You clearly understand the dynamics of noseload, and as you point out it can greatly exceed the static value when in motion. I think you will find the car manufactures are also very aware of the difference between static and dynamic loads, and their specifications take those differences into account, and the springs they fit will be adequate for the job set out in their specifications.Unfortunately in the real world the variation of the noseweight while you’re travelling can vary enormously and at times will exert a downforce on the towbar far in excess of the static loading at these times. This is when you’ll get the benefit of either the assisters or the modified springs that will help by momentarily stiffening up the spring to prevent excessive diving/pitching. It’s not something I think the manufacturers readily factor into everyday cars as the percentage used for towing a heavy trailer is so small. Hence the market for assisters and modified springs. The advantage of the MAD springs is that being a dual rate spring they are unnoticeable when unladen.
Hello Jcloughie
My posting was not about paper matching of towing ratio's.
In my time I have driven countless different combinations of tow vehicles, and trailers, and whilst I do agree some of the outfits on paper should have been fine were sometimes more troublesome than those that might have been not so good. Also I have had some combinations that were well over 100% ratio that towed brilliantly and some that were under 85% which were definitely more skittish, this is on reason why I'm not a fan of the industries towing ratio guidance figures, and what people assume they mean.
Back to this thread - It is a simple fact that provided the combination of the weight carried in the boot in conjunction with a noseload is within permissible limits, the ride height will also be within the manufacturers specifications. If it isn't, then something is wrong, and rather than mask the symptom by fitting spring assisters, the cars load and or suspension should be checked for condition or overload.
If the vehicle is in good condition and despite all the static loads being within specification, the suspension does bottom out when being driven, the problem is the accelerations produced by the motion are too great. The solution is to slow down when negotiating the obstacles that cause bottoming.
Newton's second law where Force = Mass x Acceleration works perfectly here. If you increase either or both mass or acceleration the force increases proportionately.
Even if you add spring assisters, to prevent the bottoming, the dynamic loads applied to the structure of the vehicles remain the same, its just spread over a longer time.
There is a real danger that fitting spring assistance may tempt drivers who don't appreciate the engineering principles to add load becasue its not bottoming out, or to continue to drive faster when encountering bottoming conditions. Both of these things increases the adverse loading on vehicles. Self levelling suspensions are a classic example where there is less or zero feedback to the driver about the size of the loads applied to the car.
There used to be some car manufacturers who did offer up-rated rear springs for towing, and where they did do that you can be sure they had tested the vehicles and decided that was the correct and solution. It often compromised solo comfort. Where there is no manufacturer approved up-rated spring option, such a modification falls outside of the vehicles type approval, and it the owner must report it to their insurers as a modification.
I 100% agree with Tuningdrew. It’s not about the suspension bottoming out or some driving beyond the outfits limits. The pitching can occur well before this and is not sufficiently controlled or dampened by the ow car.
Should assisters be fitted it is a good idea to let the insurance company know. But sometimes they need some convincing that it is for safety reasons.
It must also be considered that some tow vehicles can cope and are within limits. The problem may lie with the tyres. I once had it in writing from Michelin that they are aware that their supple walled premium tyres can induce pitching when towing. One car I had was massively improved by fitting non premium tyres. However I have used Michelin since, and do so now.
