Status 315
Dec 9, 2006
11
I consider to fit a Status 315 antenna, but now according to EEC rules, no longer analog but only digital signals are submitted as per Monday 11.12 in Holland (rest of Europe follows).
Does this mean that any Status is useless?
Anyone aware of this?
3,569
In the UK, digital tv signals are broadcast in the same frequency range as analogue so no immediate change of aerial is necessary.
Digital is more sensitive to signal quality and some domestic aerials may need replacing to get an adequate quality of signal. Caravans with low mounted aerials are particularly subject to digital signal degradation because there's more intrusion on line of sight than domestic roof mounted aerials.
Many caravanners already regard the Status 315 as ineffective on analogue unless in a strong signal area. Given that the UK is switching off analogue, region by region, 2008-11, purchase of a Status 315 is pretty pointless. There are estimates that 60% of UK campsites WON'T be able to receive an adequate digital signal, because they're predominately in rural areas.
A directional aerial, preferable on a mast that can be raised, would be a more sensible purchase although a portable satellite system would be more effective.
The switch off of analogue is driven by EC Directive but the timetable for each country is different.
Dec 9, 2006
11
Thank you Roger, that's just the answer I needed. I did'nt buy anything for the moment, so I can now focus on alternatives.
Apr 13, 2005
1,210
I will second that, the 530 thats fitted to my coachman as standard works very well on both analogue and digital. far far superior to the old status that was useless once more than a few mile away from the transmitter.
We also have a small sattelight system from maplins which only cost
Roger
A superb reply-respect!!
The Status 530 is indeed excellent and far superior to the 315
The best system for good reception is UK and Europe is Sky
Roger
Please read in UK not is UK !!
