Sterling water pump problem
May 5, 2018
24
I have a 2016 Sterling elite 560 & have a problem with water pump. The van has the fitting pic 1 on outside of van for shower attachment & I need to change it to a housing pic 2 that can pump from aquaroll but I can't find a plug behind housing for electrics to housing.
2,411
Hello Kevin,
I will start by saying I am not familiar with either your caravan or the details of the water system, but becasue the shower housing (pic 1) has no electrical contacts, I will have to assume that your pump is controlled by a pressure switch which will be located close to your present water pump.
This would explain why there are no wires close the the shower out let.
I'm not certain that you can simply swap the shower outlet for a pump input, becasue they are doing exactly opposite things, and the pipework may not be connected to allow it to receive water being pumped into the system at that point. There could be check or Non Return Valves that may prevent reversing the flow of water in the showers pipework.
If however your idea is correct, then you would have to put in a pair of wires in parallel to your current pumps connections to the new water inlet terminals.
May 5, 2018
24
Thanks for your input. The manual clearly shows truma ultraflow water hose for aqua roll with 2 electrical spade connectors.the van does not have a onboard tank.looks like trip to dealers.
Feb 23, 2018
889
66
4,935
Do you have any kind of attachment for your aquaroll? My Sprite has the Truma ultraflow with an onboard pump. Therefore the external connection has no electrical contact and the intake pipe terminates in a glorified strainer. It could be confused for a shower connector.
Sep 5, 2016
928
119
4,935
I have a 2008 Sterling Europa with an on board water pump that draws water from the aqua roll with the connections shown above, my shower runs off the water drawn from the aqua roll if I wanted a cold shower like I would today , if I wanted a hot shower then I would put the water heater on which would of been filled when I initially connected the aqua roll to the system when first arriving on site,
Oct 12, 2013
3,037
That pump in the above picture drops in to aqua roll and attached to the side of the caravan no electical wires at all but then you need to go on the inside of your van and switch the pump on to start it working , make sure that your dump valve is shut or the pump will pull the water through , you will hear the pump running but your water will just go straight to the drain valve and out !
We have no separate connection or separate pump for the shower either, all my water works off that one fitting that goes into the aqua roll .
Good luck .
Craig .
Sep 5, 2016
928
119
4,935
That's not a pump,but a filter, the pump is in the front of the van more than likely on the N/S ,
4,831
Agree it's an inlet hose with a strainer. Ours is identical and the pump sits inboard under the front locker adjacent to the hot water heater tank.
Oct 12, 2013
3,037
Apologies !
I do not mean that was a pump , I'm getting my words mixed up ! the pumps on the inside. :blush:
Been a long day !!
May 5, 2018
24
Thanks for the suggestions, I will order the inlet hose. The shower I referred to plugs into housing outside to wash boots etc not the shower inside van.
Feb 23, 2018
889
66
4,935
I belive the outdoor shower uses the same Truma connector but would be a separate panel on the caravan wall.
Did your Sterling not come with the inlet hose?
Oct 12, 2013
3,037
Have you got a panel on the wall of the caravan extra so that you can plug in your shower connection externally or not?
May 5, 2018
24
No extra panel inside or outside. The out side one has a shower symbol on inside of lid so I thought someone had changed it.
Oct 12, 2013
3,037
I've never actually noticed on mine whether I can put an attachment onto that but I will look next time we have it out ?! Custard Avenger , is yours like that or just a normal water intake?
A slight Curiosity thanks !! :blink:
Craig .
Feb 23, 2018
889
66
4,935
Craig .
Hi Craig,
Just been outside an had a look - I have the original recipe Sprite, so there are no other external flaps on the offside except for the battery box, water inlet and the cassette toilet/flush tank openings.
The cover says "Truma - Ultraflow Water Intake" and has the sticker on the inside "To be used with drinking water only"... But it does have the shower icon above the inlet port... This is definitely the correct port for water.
I can only assume that they use the same panel as the external shower for the water intake when used with an internal fixed pump as no electrical connectors are needed (saving money on the moulds!) for a submersible pump.
Paul.
2,147
On my Coachman 560 the Truma water point, has the water inlet from the aqua roll, ( pump on the end of the hose and electrical connectors,) the cap of the water filter and the outside shower connection, blanked off. All under one cover flap.
I Can't post photos again as Chrome has updated again. :woohoo:
2,147
Thats what I was using Craig, Postimg.org, changed back to older version of Chrome and it works as soon as it updated to version 126, it freezes.
Feb 23, 2018
889
66
4,935
Took some pictures of the water inlet... but I don't know if you can host images from Google Drive... so here is the link
https://drive.google.com/folderview?id=1LUTcAgPpwivYa4w4Ah-2ABRwII511YqG
Shower icon and all...
2,147
Good Photos custard, the Truma connection is the one with the electrics fot the Drop in water pump to the aqua roll. And the shower connection is the same but without the connectors.
Oct 12, 2013
3,037
Ours is getting serviced next week so will have a look at the fittings outside when I pick it up .
Thank you Paul.
