Swift Challenger Locking Door
Oct 21, 2020
413
260
10,935
Possibly been used as a spares source if it was standing for a short while at the dealers, we had a few similar issues with our new van but did buy it sold as seen - easily fixed and was worth the cash saving.
Kev
5,436
Kev
No such thing as "sold as seen" if buying from a dealer.
413
260
10,935
It was bought sold as seen with the issues highlighted. It did carry the usual manufacturers warranty, the invoice was noted as such.
Aug 5, 2023
656
279
2,135
Video here
View: https://www.youtube.com/watch?v=I8orD3K8gR0
He ends up taking the whole plate off. For us, just turning it around sorted it. Hope this will solve it for you
Tried exactly like this and the door lock still didn’t close properly, and I flipped the recess section around. Had the exact same issue after the guy on video flipped it
Maybe it’s another trip to the dealer after all, which is a shame as it just needs a file down then the lock would pass over. Still needs a good pull / slam to engage
413
260
10,935
It was heavily discounted due to some issues relating to parts having been removed during storage.
Soon sorted.
I was at a highly recommended dealer last week, in a couple of the new vans there were various parts missing, seems to be common practise.
Reactions: Hutch and Dustydog
Aug 5, 2023
656
279
2,135
Ok travelled to the dealership in Scotland today to point out the door snag.
The Tech came out and said it was normal for Swift users to slam the door so the lock mechanism can engage. I said it wasn’t good for the neighbours hearing that at 11pm at night, he sort of gave the look of ‘why should we be so bothered about others..’
Can any of you who are in their Swift caravan please take a photo of their mechanism and advise if it’s the same as ours and have you got to slam the door for the 2 silver bolts to engage and lock?
  • Wow
166
72
18,635
We have a Swift. . I was concerned about slamming the door. Or worried about the strain on the handle when trying to shut quietly. . A bit of silicone spray on the latch made it shut easier. . .
Reactions: Saxo Appeal
2,327
As I mentioned before ours ( Swift Alpine 2) was a slammer until we turned the latch plate around; now it just needs a definite pull, rather than a slam.
Our mechanism is exactly the same as yours. Van in storage so can’t do photo at present.
BTW I found out about the latch plate being the wrong way around on Facebook posts in two Swift and Swift/Sprite owners groups. It is a common issue. If you are on FB, it may be worth a trawl.
9,437
But hasn’t Saxo reversed the plate with improvement. #31
5,488
I wonder if the actual door seals are incorrect and require more compression to close than necessary?
9,437
Yes he has but in his case it still needed a slam as per the video I posted.
Apologies I should have said “no improvement “. Didn’t watch the video as I’ve not got a new roaming VPN yet😂
Reactions: Mel
Aug 5, 2023
656
279
2,135
Yes will try Mel, but not sure if they will fix this!
I would need to have someone upload a Swift caravan on their door so I can send him an example. He was very adamant you do need to slam the door..
I also checked another brand new Swift at the dealership and they too had the plate reversed, and the door had to be slammed shut.
Nov 4, 2007
166
72
18,635
In my mind, why would Swift supply caravans with the latch plate the wrong way round? . . My thoughts are the door seals need compressing to guarantee a watertight fit. .
4,715
I have asked my brother , who has a 2023 Swift if he can send me a couple of pictures of his lock. He says he has to pull it really hard to get the pins to close properly.
Mar 26, 2016
55
37
18,585
I happened to visit a certain dealership on the outskirts of Shrewsbury for some odds and ends from the accessories shop yesterday. While there we looked at some caravans (after promising each other we wouldn't make any rash purchasing decisions).
Some of the vans we looked at were Swifts and that reminded me of this thread so I started checking the door locks, all had the strike plates how yours were originally. I didn't try shutting any doors though.
May 30, 2024
119
144
635
The strike plate on my 2024 is also fitted the original 'wrong' way. I expect they all come out of the factory like that, and actually it will be in the manufacturing specification that the lock assembly is put together that way as standard by Swift's supplier when they ship it to them.
I'm more of the opinion now that that is the 'correct' way.
When we're inside the van, we normally just pull the door gently to the first latch position. We don't attempt to lock it - why would you when you're inside anyway? There's enough of a detent that the door is never going to blow open (though if the weather is really wild then I might slam the door shut so I can lock it).
When we're not in the van, we always close the door firmly, compressing the rubber seals, and lock it. It's totally a good thing that it takes some force to squeeze the rubber seal so that it limits water ingress when towing or in wild weather. Really it's the locking pins that do the main job of holding the compressed position, but it helps that the latch is holding the door in tightly because then the locking pins are engaged easily with the key. If the strike plate is adjusted so that the door is not held in as tightly, then you might be relying on the locking pins twisted by the key to pull it in the last couple of mm.
Having said all that, the assembly is good in that it provides options for people to adjust to suit their own preferences!
2,646
Just looking at my Swift Conqueror door lock it does not look like your door lock it totally different and we went to Salop caravan dealers yesterday probabably you need to compare them both .
Sep 2, 2023
128
89
1,635
Very interesting thread as I have exactly this issue on our 2019 Swift Challenger 480 and have always thought, "this can't be right!!".
When we viewed the van at the dealership prior to purchase I noticed that I had to slam the door to get it to close properly, (sometimes having to make 2 or 3 attempts), and mentioned it to the sales guy who said it wasn't faulty and gave it a right good 'slam' which of course closed it. I accepted his explanation thinking that I had been over gentle as I hate using excessive force on anything mechanical especially where plastic is involved!!
I'll check our plate to see if its been fitted incorrectly when I next visit the van in storeage and report back very soon.
656
279
2,135
The fault (along with a couple others) have now been accepted by the dealership.
looking at the lock plate when the door is just about closed, it's definetely not fitted correctly.
If you have a look at the image below. The lock plate is roughly 1/2cm lower, which stops the actual lock snib from engaging properly. I'm sure the dealership said they will try lowering the plate first, which will presumaby allow the lock to engage more easily without slamming the door every time.... which I know is wrong
9,437
Progress of sorts but from some of your previous posts, and others I wonder how Swift got it so wrong?
Aug 5, 2023
656
279
2,135
Probably the same guy signing off all the caravans thinking its correct ;)
1. Close door (check)
2. Door Closes (check)
3. Door Opens (check) all complete
4. Seats fold up....
