- Apr 20, 2009
- 75
- 0
- 0
I guess I am another victim of 250 frost damage. The WC failed to flush and the fuse was blown. Replacement fuse but still no flush. I have checked the contacts under the flush button and get power when the button is pressed, so I assume the pump is defective and will need to be replaced. As far as I can see, the pump supply cable is one continuous length from the circuit board to the pump. So am I correct in assuming I will need to cut the cable in order to remove the old pump and fit bullet type connectors to connect the replacement? I would appreciate any tips from those who have successfully dealt with this.
I find it more than irritating that after many years and several models of WC, Thetford are able to supply the caravan industry with a new model with such a silly fault.
