Thetford C260 toilet
May 20, 2022
when we came to use our caravan for the first time this year we discovered that the toilet would not flush. The fuse was ok so we have replaced the pump with a new one but it still refuses to flush. Any ideas please
9,140
If it is one with the soft touch membrane panel it could be the contacts within the panel are poor. Its easy to remove the top membrane and access the pcb and contacts. I used electrical contact cleaner and some very fine emery and after replacing the pccb as an additional measure sprayed a coat of pcb lacquer. Never had problem again. Sometime the wiring in the flush tank compartment can become corroded so clean the joints too. Helpful videos on Youtube.
Reactions: MonkeySocks
