Thetford loo
Mar 24, 2008
7
Hello.We have been getting an anoying problem with the cassette loo in our Lunar Clubman.It seems that the flush will work when it feels like it or when we have taken everything out of the cassette and put it back again only to stop again a short time later.Any idea what is causing the problem and any solutions(sorry if this topic has already been covered)We have sprayed wd40 and cleaned every thing several times over but the problem persist.Hope there is an answer out there as I am fed up spending time trying to fix the loo whilst we are away.Thanks.Paul
It would help to know which model of Thetford loo you've got.
If it's an electrical flush, then I don't know the problem, but on the assumption that it's a hand operated one (most are)....read on.
By the sound of it, you have a problem with the flush mechanism, which does not have anything to do with the removable cassette. Therefore removing and stripping down the cassette unit is unlikely to help.
Thetford loos come in two parts.
The removable part is the cassette, which lifts out of the side locker,when full of waste, for emptying and cleaning. These are pretty foolproof, and work well, so long as they are looked after, and the seals lubricated occasionally.
The tank unit,however, is built into the structure of the caravan, and comprises the seat,lid, flush knob and mechanism, and release valve for emptying the contents of the bowl into the cassette.
If you have a problem with the flush mechanism, then you will have to investigate further, from inside the caravan.
I've not had this problem, but Thetford may be able to send you details/ diagrams of how to get to the flush mechanism, and repair it. They are one of the most helpful of caravan accessory manufacturers.
If you have a Thetford Manual for the loo you've got, then it will have this information in it.
They also have an excellent website, and you could email them.
Hope this helps you.
936
Paul, what model toilet is it?
The answer to your problem will be different depending which it is.
Mar 24, 2008
7
Ok,thanks for your replies,my van is kept 40 miles away so I will check on model etc next time I go up there.Heres to a happy flushing 2009
Jun 17, 2011
826
27
The Thetford web site has a number of good explanatory sheets to download. Have a look there. Your problem is probably with the pump.
