I will check voltage tomorrow when we go up to storage and let you know , thanksWhat voltage is the leisure battery reading. If you are on a mains hook up should be 13,6 volts If not on hookup charged battery should read 12,6 volts. If voltage low could be the problem but best checked is back of fridge voltage
oh I know I do to want to spend that at all 😳You will need to be sitting down when you check the cost of a new fridge! You will need to rip out an internal organ, and thats just for the deposit 😱
thank you will contact themIf you go on the AWS website you will be able to find caravan workshops near you. I did a search 30 miles around Lancaster and found quite a few.
Good luck. Hope someone can help within budgetFind an Approved Workshop in your local area
Find your nearest fixed or mobile Approved Workshop today using the interactive mapwww.approvedworkshops.co.uk
