Thetford toilet
May 24, 2014
3,687
763
Never had a problem with it staining, could it be scrtched by the use of an abrasive cleaner? We have had six vans and never had the problem. Im guessing a mild solution of bleach would do the trick.
Jun 17, 2011
826
26
Try the following, at your own risk as they say. Splash some vinegar on a small part of the stain. Leave it 20 mins and wipe it. If stain goes then you know what to do if it lightens try repeating it. If this works you might want to try citric acid instead- it doesn't smell! If vinegar doesn't work try a good car polish- this puts a coat on the surface. If the surface is rough the top coat might have gone, there is a gel cleaner available at marinas that might help.
