Thetford toilet
With IDC connectors you do not strip back the insulation , the insulation holds onto the metal 'tooth' within the connector The action of closing the lid normally pushes the wire onto the blade and completes the action , however with the ones you have bought, the cover closes on a hinge so the little plastic 'tabs' don't come down on the wire at right angles and aren't very strong . I prefer to press each wire onto the respective 'tooth' .Then once all four are fitted,close the cap to secure the connector onto the wires.See the attached photos . The first one shows a wire being placed onto the 'tooth' and the second one ,with the connector on a secure flat surface I have pressed the wire fully onto the tooth with a small piece of steel rod(its actually an old small screwdriver with the end ground flat). you can see the edges of the 'tooth' protruding either side of the wire.Closing the cap completes the process
I have a similar infuriating issue. Thetford C250.
Push button stopped working.
I have replaced PCB, didn’t work
Replaced reed switch pcb. Didn’t work.
Just replaced full pump & wiring loom. Doesn’t work!
Fuse is fine and there is 13.5v at the connector in the cassette hatch.
Any further ideas before I set the whole thing on fire !! 😡
Back of cassette should be fuse often corroded. With cassette out at the right side of the door opening at the front floor corner is a small plastic panel. If you lever this out you usually find a connector there. Check if you have voltage there comming from the consumer unit.
Check the voltage at the flush pcb , both with the pump switch off and then pressed , if the voltage drops then the wiring from the cassette area is knackered and the loom needs replacing. ,attached is a schematic diagram of the wiring. there are slight variations in the pcb layout but it should help you determine where the voltage is being lost. Also don't assume its the +12V supply thats faulty , a faulty 0V will give similar results so if you can, run a wire from the battery negative and use that as your 0V reference for your multimeter to check voltages and if the 0V at the pcb rises to about 10-12V when you press the flush switch its the 0V ( black wire) which is faulty(high resistance).
Hi thanks for replies.
I have 12v (13.5) at the connector in the cassette hatch. I have put a brand new, genuine pump and wiring loom in. Changed the fuse , changed the pcb switch and the reed pcb at the back .. I’m at a loss !! 🤷‍♂️
Hi guys thanks for your help so far but still do but have toilet working
New pump power coming into PCB
I have X question is it possible to buy pass the PCB board and just have a switch to flick to do the same job
I hadn’t seen this thread when I posted https://forums.practicalcaravan.com/threads/bog-side-failure🙉.72001/
The old pump was seized.
The old pcb looked its 18 years
New pump and new pcb, delivered to site last week worked for 24 hours then died.
13.4 volts available across the Red and black wires. Nothing across the brown and blue with button pressed.
Hot wired new pump to a 12 v source. Runs perfectly.
Purchased another Thetford new pcb but not fitted it yet.
I ‘ve read this thread in its entirety. How strange two,of us have the same issue.
Before I mess up the new new pcb any further thoughts?
Clive, I like your suggestion. Is it ok to hot wire the pump by passing the pcb? Not bothered about the red light. We empty the waste tank daily.
Where best to position a new switch?
I think if you are not fussed about the red warning light, and we never were as we had eyes and ears, you can isolate the pcb totally then rewire via the 12v supply and return. Position the switch were most convenient for wiring and usage. You could even convert it to a Gerberit type shower toilet and save on paper. 🙈
You really are going The whole hog, towards taking over the "Throne of The Woosies". It's all coming together nicely. 😈👿
This has really bogged me out.
I thought I’d got to the crown of the problem🙀
If the 3 rd pcb doesn’t work it’s back to the jug of water and in due course I’ll fit a diy switch per Clive’s suggestion. I hate technical mysteries. 🙉
I did this on one of our Caravans back in 2009. The board packed up whilst on holiday and I never rely on full light( eyesight does it for me). End washroom and toilet next to wardrobe. So ran a wire from the toilet input connector bottom of cassette compartment through the cables floor trunking to the wardrobe and fitted a switch with a return wire back to the pump. Totally bypassing the circuit board
It's going to be something stupidly simple, good luck.
Even if you fix it this time it could easily go again. Life expectancy seems very variable. Whereas a simple switch is unlikely to go wrong.
Spotted by one of my associates in the MCEA.
Good job it wasn't a Ring doorbell (with camera), no pun intended ( oh yes it was!)
Reactions: Mel
