Thump when braking
Aug 23, 2023
31
13
535
I tow n Abbey GTS 416 with a 2.2D Mercedes. I know I am on the weight limit.
Often when I brake, there is an audible “thump”. I don’t recall this from previous caravans.
Is this normal or ought I be concerned? The van was serviced recently, and the noise predated tge service.
Oct 19, 2023
540
417
1,135
Over run damper would be my first guess too. Easy one to test. With the caravan held on the hand brake you should be able to push the hitch and compress the damper. It takes a lot of effort and will move very slowly. When released, the hitch should extend very slowly on its own.
3,934
The fact is you shouldn't hear or feel a distinct thump when you brake. You need to get both the caravans braking and your tow bar checked out . The braking should be progressive and smooth. If you can feel a thump, that is transfering quite a lot of shock loading to the tow bar and it can loosen some fixing bolts and cause damage to the underside of the car.
