- Nov 11, 2009
- 25,018
- 9,049
- 50,935
As one who had a combination of Imperial and SI through university then at work most times it would be Imperial units. But I never dropped SI totally so when doing calcs I’d tend to use SI then convert at the end to imperial so others could understand the outcome.Clive. I think you are the first person I know who uses kpa. I grew up with psi and bar . What does everyone else use?
Between solo and full load my rear tyres go up 10 kpa……. 1.45psi Only Subarus persnickety approach would put such a small difference on the label. But what do you expect of a company that requires all four tyres to be within 1 mm tread depth 😂
