- Apr 7, 2012
- 16
- 0
- 0
I have been told that the pink stuff makes your toilet have black slimmy stuff under the rim and to only use plain water in the top tank, which if any doesnt make black stuff because I do want the toilet to smell nice.
Kind of makes you wonder why Thetford sell "Pink" for their toilets unless it's to increase the sale of replacement pumps.Damian-Moderator said:The pink additive not only makes black algae under the rim of the toilet, it also invades the flush tank, all the pipewoek, and will eventually block the pump and you will need a new one, as well as cleaning out the whole flushing system.
We have been using Elsan pink in our flush system for years and have never had an issue.Damian-Moderator said:The pink additive not only makes black algae under the rim of the toilet, it also invades the flush tank, all the pipewoek, and will eventually block the pump and you will need a new one, as well as cleaning out the whole flushing system.
Plain water in the flush tank, no additives,especially toilet tank blocks, as they will ruin the pump also.
Just a spray dettox or similar wil keep the toilet smelling OK
Woodlands Camper said:Is it just a particular make of pink that is causing problems?
So far Elsan has been ruled out.
What do you use paws?
Gagakev said:Ah my favourite Topic
..... Woosie Pots![]()
I previously used Thetford pink on my last van and had the black gunge, vowed when I got this van not to use any again and used just water for a long while but eventually.......
You do tend to get un-pleasent aroma's.
