Hi mrw5646,
One of the major and recurring problems of using tow matching services, is they all use different databases, and I am pretty certain ALL of these data bases contain some errors or omit some details. This means you mustn't implicitly trust any result from them. It is vitally important for the details they have about cars and caravan are for the exact make and model, becasue similar models may have some very different technical detail that affects their towing characteristics. Even the level of trim (eg, Grand Luxury vs Grand Luxury Sport) has been known to affect towing performance even though the same engine and power is available. This can be a particular issue with sites based abroad where multinational car companies sell what appear to be the same car, but it may well have different specifications in different markets.
The basic caravan industry calculation is the towing ratio where the 100 x caravan's MTPLM/Cars Kerbweight. This produces a percentage figure. This is always based on the worst case scenario, (Empty car and fully loaded caravan) and uses the paper based document figures and never changes for that outfit, except where the cars own specification limits towing to a lower figure. Some versions of cars are not even permitted to tow anything.
The caravan industry uses this calulation to provide guidance for caravanners. It recommends novice caravanners limit their first towing experience to a towing ratio of 85%. It goes on to suggest the ratio can increase as you gain experience, but they reccomend (subject to the tow cars specification) you should never exceed a ratio of 100%. All this guidance is just that - Guidance and has no basis in law.
Whilst I suspect it doesn't apply to you, drivers with licence issued since 1st Jan 1997 do have a weight ratio limit applied in so far that Entitlement B limits the Trailers MAM must not exceed the tow vehicles ULW. and the combined MAM of car + caravan must not exceed 3500kg.
Based on the figures you have supplied Woodland Camper has worked out your towing ratio at 94%. As a truck driver you will probably be aware of side wind issues and especially empty tall sided trucks, well caravans are definitely a bit more complex becasue of the way they are counterbalanced, and are coupled to a relatively light towing vehicle. With reasonable care though such things are manageable and shouldn't put you off.
I personally find the towing experience is not directly attributable to the the actual towing ratio, but more to do with how the caravan and car are loaded. Good loading practice creates and controls the nose load, and that has more to do with good towing than ratio alone.
Many of the skills and experience you have as a truck driver will be an advantage as a caravanner, for example the use of the side mirrors, anticipating the space you need on the road, the relative performance of a car towing compared to the solo car. The way other (unreasonable) drivers may treat you because you are towing a caravan, and the speed restrictions that apply.
If you have never towed before, then it may pay to find an area where you can practice reversing the outfit.
