camel said:
Prof,
What system would you use to measure your nose weight because whichever method you use it is not covered by the Weights and Measures act, so one way can't be any better than the other way whatever way that is to measure nose weight, but I've just ordered a Reich weight control that fits on the tow ball, now it must be good it is German,
In my career, have had access to a number of different calibrated measuring systems, which have allowed nose load to be measured with a at least 1kg resolution of certainty. But since leaving that and doing domestic towing I have used bathroom scales.
Your are correct that none of the domestic systems are covered by weights an measures, so the accuracy and repeatability are not verifiable, but at least with a set of bathroom scales there is a possibility the owner can get a fair idea of their accuracy by loading them with known weights, (25kg bag of sand, known volumes of water becasue 1 Litre weighs 1kg, or as someone has suggested weight lifting weights. which can demonstrate both the sort of relevant accuracy and the repeatably. That is something you cannot do with the collapsible spring gauges most commonly , it's almost impossible.
Secondly the compressible spring gauges are usually coarsely graduated and it is very easy to inadvertently read the scale with a parallax error. bathroom scales are have much finer graduations and smaller parallax reading errors and of course there are digital scaled that eliminate parallax altogether.
Bathroom scales even the metal spring varieties have a very small compression movement when loaded in the order of 5 to 10mm Max where as the compressible nose load gauges of ten have 150mm range of movement.
So on balance I'd trust bathroom scales over any stick type nose load gauge.
You have mentioned the Reich product. This fails to meet the criteria, becasue it raises the tow hitch by about 75mm, so it is not measuring the actual nose load which for accuracy must be done at the towed height. Reich acknowledge this by stating its compensates for it, BUT, as the device has no method of entering the dimensions of the car and caravan, and you cannot know the actual vertical height of the caravans centre of gravity, the compensation it provides is at best a guess and not a proper mathematical calculation.
The problem is even worse where its a twin axle caravan, where the height to nose load change of the hitch is far more aggressive, and depending a number of factors it can be positive or negative.
