otherclive said:
I had a problem once on a car that I bought. I used Belzona which is an epoxide compound used extensively in the marine industry for repairs to castings and bearing surfaces. But these days two part epoxy compounds are readily available at DIY and automotive outlets. They come under various names but you just cut a slice and its like a soft putty which you mix by rubbing it in your hands. Then apply to the towball and after 10-20 minutes its easy to sand smooth. It will then have no effect on the stabiliser performance but will prevent friction pad wear and dirt pick up.
Hello Clive,
I'm very concerned with your suggestion of using an epoxy compound to repair pitting on the surface of the tow ball. The conditions and function of the surface are very different to bearing shells, and whilst the properties of some epoxies may be compatible with the function you describe, I think its very uncertain they will be suitable for a tow ball used as part of a friction stabiliser.
Stabilisers rely on the very high sheer strength of the tow ball surface to resist the motion of the friction pads. The pads whist may have the appearance of being smooth, actually have very very fine abrasive properties. If the tow balls were not so hard and strong they would wear away quite quickly.
The characteristic of the epoxy you describe where the cured compound can be shaped by common abrasives gives a clue to it poor sheer strength. The action of a friction pad in a stabiliser will be like an abrasive to the epoxy. The secondary effect is the dust from epoxy compounds is usually very fine and is rather like talcum powder. Talc acts like a lubricant which is contrary to the required function of a stabiliser.
I cannot recommend common epoxies for this repair.
In practice I don't think the pitting is likely to be a major problem unless it is significantly reducing the surface integrity and reducing the nominal diameter of the ball, and consequently I don't think any remedial action is necessary, It does make sense to protect the ball form future rusting, but do ensure any protective coatings are removed thoroughly before use.
