ProfJohnL said:Dustydog said:Seriously eroded[/ProfJohnL said:Raywood said:Possibly guaranteed safe towing is not quite right but a good ratio should make the outfit safe.
As for bow waves I find that they only ones that disturb our outfit to any extent are the white van men passing at speeds well over 70.
a good ratio low ratio is likely to be safer than a big ratio, but that is not the same as saying it is "safe" which implies there is no danger or risk.
A solo car has its stability margins seriously eroded when it becomes a tow car, so in no way can towing be described as "safe", it requires greater attention from the driver and any lapse of that attention has a greater chance of becoming a serious incident. I place this use of the word safe in the same group a "rule " for weight ratio's as neither can be a definite outcome of the practice.
Prof,
Not quite your usual stance
A seriously eroded performance may be crying out for some intervention like suspension aids etc?
Surely most vehicles designs take into account towing within the prescribed and recognised limits
I’d hate us to deter the newbies :woohoo:
I stand by my statement, but perhaps it needs a little clarification. Something that looses half or more of its potential is seriously eroded, so for example the rate of acceleration of a car and caravan is roughly half that of the solo car. This does not mean its incapable, just less able. that is the easy one, but handling with a caravan in tow puts a lot more stress through the car its suspension and tyres, again they should have been specified adequately by the manufacturer but definitely with a caravan in tow it will eat up any of the available margin.
So no its not a change of stance, and i still maintain no car requires spring assisters as per my previous posts.
I really do feel the need to interject here guys, and to say that a car’s stability margins become seriously eroded when it becomes a tow car is a gross understatement.
First of all, I think one needs to define stability, or at least the audience’s understanding of the term “stability” when applied to a vehicle ...
It is commonplace for motorsport enthusiasts and professional racing drivers to regularly and intentionallly drive a solo car way beyond what one would generally consider to be the limits of stability. However, the key difference here is that they are driving a vehicle with a rigid body, designed and engineered to be predictable, and irrespective of their skill level, their ability to keep the car under “control” is determined by their reaction time, in response to the change in stance of the vehicle, caused by a sudden change in force (of either magnitude, direction or both), as a result of whatever situation they deliberately choose to invoke, be it understeer or oversteer, and at whatever speed. The magnitude and direction of the forces at play here are even pre-determined by the drivers own deliberate actions, and they can feel exactly what the car is doing, and as the forces at play are not too great in magnitude, or (more importantly) in frequency of change in direction, they are able to react quick enough to provide a counter-reaction to bring the car back in line. There really is no unpredictability here, except from perhaps a little margin for error due changeable road surface conditions.
In such a situation, whilst of course the relationship isn’t directly proportional, in general, the reaction time required to “control” the situation is inversely related to the force he/she is attempting to counteract, and passenger cars are fundamentally engineered and designed this way.
However, when that vehicle becomes a tow car, that’s a complete game changer, and for one key reason. When a car and caravan combination becomes completely unstable, the 3-dimensional forces acting on the tow ball are of such magnitude and more critically of such rapid change in direction and unpredictability, that no driver, however skilled they think they may be, can react quick enough to confidently bring the outfit under control. And to look at the bigger, and much more complex picture here, it’s not only the reaction of the driver that must be considered, but even parameters such as the reaction of the tyres of both the car and caravan, the “drive-by-wire” throttle and brake response, and the suspension of both the car and caravan and the “tank slapper” effect of the contents of the cars fuel tank as the rear of the car is violently shifted from one side to the other.
Reverting back to my original point, in terms of quantifiability, the stability of a modern, well maintained solo car and that of a car towing a caravan are not even on the same spectrum, however safe one considers their outfit to be.
