Towing mirrors for Audi A6
Jan 20, 2023
1,271
1,114
2,435
I'm struggling with my tried and trusted Milenco mirrors on my 2024 Audi A6, the mirrors hit the door glass when they fold in on locking (yes, this can be disabled but I forget every damn time.....) but more worrying is that the clamps on the mirrors don't fit well on the mirror housings due to their shape and the lack of clearance/gap for the clamp leg to insert fully between the mirror housing and glass,
Before everyone shouts EMUK!!!!! they aren't available for UK spec C8 A6's (already spoke to them), so are there any others out there that offer a secure connection to the car????
Jan 20, 2023
1,271
1,114
2,435
Fit/adjust the Milencos when the door mirrors are folded.
You cannot do that, infinite adjusting won't clear the door glass when folding. Even if they did clear it doesn't solve the issue of not clamping the mirror housing securely.
Jan 20, 2023
1,271
1,114
2,435
Suck it & See Delux. They suck onto the mirror glass
Looked at those as they overcome the clamping issue but the problem is the mirrors fold in so tight to the door glass that any towing mirror that has anything projecting forward of the mirror hits the door glass when folding.
Jan 20, 2023
1,271
1,114
2,435
Have you contacted Audi, they might help 👍
Yes and no are the relevant answers there! To be fair they did go away and ask and suggested EMUK but sadly they don't fit the UK versions. It's trivial I know but irritating at the same time!
2,485
I cannot explain how I did it as it has been a few years since I had the issue, but I remember altering the top of the clamp which holds the bar so the one nearest the window was to the rear of the car and the outside one towards the front. So that the bar was no longer parrellel to the car mirror. In this way, when the car mirrors closed, the towing mirrors were held away.
Reactions: GaryB and RogerL
Jan 20, 2023
1,271
1,114
2,435
I have now sorted the "hitting the door glass" issue. In the end I removed the mirror knuckle joint from the arm extension and re-drilled it's hole a few degrees further round, this enabled the cranked part of the arm to face further forwards, thus putting the mirror a bit further forward and (just!) misses the door glass now.
