Hello Brian,
You are seeking a simple yes or no answer, In some cases it is quite straight forward to do so, but with the combination of the car and caravan you have given, along with being new to caravanning this raises some other concerns so a conclusive answer cannot be given.
On balance I cannot recommend the proposed outfit, and depending on your driving licence, it may be illegal for the following reasons:-.
The quick calculation of the theoretical towing ratio:
(Caravan MTPLM/Cars Kerb Weight) x 100% gives us (1630/1478)x 100 = 110%
This sets alarm bells going immediately. Whilst the weight of the caravan is within the manufactures mechanical specification (1800Kg) it is recommended that the ratio should be as small as possible. The Caravan industry offer a guideline of only 85%, and most experienced caravanners wince at anything over or close to 100%
There are some important bits of information that you have not given us.
You have given us the cars mass in service, its maximum permissible mass and its maximum towable mass figures but in addition all cars are given a Gross Train Weight (GTW) figure. This is the largest weight figure stamped on the vehicles VIN plate. This is the heaviest that a car and coupled trailer is allowed to be.
The GTW is important because with some cars when they are fully loaded you cannot then pull the largest trailer as it may exceed the GTW. I do not know if the Mondeos GTW is less than the Combined MAM.
You may be limited by your licence on what you can tow. I note you tells us you are new to caravanning, this might also mean you passed your test after Jan 1997.
The law changed in Jan 1997, and new drivers were not given the +E category after passing their basic test. This limits new drivers to combinations of car and braked trailers that are less than 3500Kg combined MAM. MAM is the Maximum Authorised Mass. (MAM is equivalent to the MPM or GVW or MTPLM). In addition you are legally limited to a combination where the towing ratio is no grater than 100%.
If these limits apply to you are scuppered on both counts. Your car has a MAM of 2015Kg and your caravan has a MAM of 1630Kg that gives a total of 3645Kgm, which exceeds the licence limit of 3500Kg, and the caravans MTPLM is greater than the cars kerb weight.
