Towing with ESP
I have been reading a thread on UK Kia forum about the use of ESP when towing. After viewing the demonstration of driving too quickly into corners and seeing the effect of the ESP contolling an out of control vehicle its very reassuring if you have it fitted. But will this help at all in contolling a snake or similar? Some have even suggested turning it off when towing.Does anyone have any knowledge on this question?
Regards Jim
No its not that good but it certainly gets you through the corners.See this link
www.whatcar.com/news-special-report.aspx?NA=220063&EL=3159817
PC mag has a feature on Al-Ko fitting ESP to some of their chassis.
I was rather hoping some of the techies might reply, perhaps they are all away on this lovely Bank Holiday.
Jim
Jul 15, 2005
2,175
Hi Jim,
This was discussed on this forum in reasonable detail less than 4 weeks ago - a search should locate the thread for you.
Basically there are two types of ESP stability systems fitted to cars and they use the car ABS system to automatically brake wheels and improve stability; the first generation systems brake the wheels in pairs, and the new ESP+ systems brake individual wheels.
ESP+ (VW / Audi, BMW, Mercedes, Opel / Vauxhall and maybe others) has the big advantage to a caravanner of enabling a further ESP mode called TSP or TSA. These are Trailer Stability Systems which modify the ESP response to reduce fishtailing / snaking when towing.
If your car has ESP+ and TSP - at the moment only certain European made cars - then results of German ADAC, Dutch VVV and other motoring organisations or independent testers are truly impressive.
If your car has the old ESP system - then the systems fitted to some cars may help, some possibly may be worse. And you can't retro-fit TSP or TSA to a car with ESP - it doesn't have the underlying ABS sensors.
Robert
946
Generally, if a car fitted with ESP+ is ordered with a genuine factory-fitted towbar (as opposed to a dealer-fitted one) it will automatically have TSP or TSA.
Don't confuse this system with electronic stabilisers for caravans, like the AlKo ATC or the LEAS system, though. These act on the caravan brakes whereas TSP or TSA acts on the car's braking system, so the two actually complement each other.
With both systems fitted, it is virtually impossible to get into trouble with instability, no matter how badly the load is distributed inside the caravan or how high the weight ratio is. Even with only one of the two systems fitted, the outfit will be well nigh foolproof.
Jul 31, 2006
417
Jim,
Below is the relevant paragraph in my reply to the TSP question in the "technical" section, read from where it says "and you drive in such a manner as to invoke the ESP whilst towng"
""Although the TSP uses the simular technology as ESP (Electronic Suspension Programming) and utilises the selective braking process, TSP is NOT linked to the ESP, indeed if you have a vehicle with TSP the ESP will probably never come into operation, but if your vehicle has only ESP, or has TSP, and you drive in such a manner as to invoke the ESP whilst towng a caravan, you've already lost control of the outfit and will be extremely lucky if you don't loose it big time!""
Having said all that, my Audi is fitted with ESP (Electronic Suspension Programming) and I never switch it off even when towing, I've even enquired with Al-Ko as to when their ATC will be available, anything that makes it safer to tow can't be a bad thing, but always remember, matching the outfit to the car, loading the van correctly, taking proper account of the nose weight should always be the first course of action, no suplimentary safety system, ESP TSP & ATC can cope with a badly matched & a badly loaded caravan for long
946
I don't know where your source got the information from that TSP is not linked to ESP. Of course it is. In fact it needs ESP to work at all. TSP can be considered a 'hang on' supplementary feature added to ESP.
ps: ESP is not "Electronic Suspension Programming" but "Electronic Stabilisation Program" (refer to the Audi glossary)
946
Also, you mention (quote) "....no suplimentary (sic) safety system, ESP TSP & ATC can cope with a badly matched & a badly loaded caravan for long".
That is also not true. The system will always cope with the conditions mentioned so long as the brakes don't fade. In critical situations it will deploy well before the actual speed limit is reached and prevent the outfit from going any faster.
I have just read the threads in Technical and they make interesting reading. I have a Kia Sorento XT which has ESP, I am waiting for a reply from Kia Technical to confirm if the system also has TSP. I dont think it does however. If I only have ESP it is debateable from the threads I have read if this would make towing any safer in my case.Thanks to everyone for their input.
Regards Jim
Nov 9, 2006
72
im lost ,
est,tsp atc.
im lost,
esp,tsp atc.
Does this mean i cannot tow my caravan,many years ago ,my family consisted of my wife 2children mom and dad in law driving down to cornwall without any idea of towing or caravaning.Twenty seven years later i tow one of the biggest vans legally in this country,i have taken on board all the wisdom of every caravaner i came across,we never hade these abbreviations ,we had at best gross laden weight ,and every time we travelled to cornwall in the early 80s the weight of my car and the weight of my van was cellotaped to the inside of my ford sierra, just in case the cornish police ever pulled us over .ESP,TSP ATC please lets just enjoy , but be safe.
jim
946
All these fancy electronic gubbins are only there to make towing more foolproof, Jim. If you're an experienced caravanner and you know how to react in the event of a sudden hazard you may never need them but the idea is to make towing just as safe for a novice who has just taken delivery of his first outfit right on the edge of the legal weight limit, without regard for any 85% weight ratio recommendation, and probably without even ditributing the load properly.
ESP - Extra Sensory Perception - what else could it possibly stand for. My wife has been fitted with this for years. She reckons she knows exactly what I am thinking, about to say or about to do.
Jan 12, 2007
81
Hi, I posted a question a few weeks ago regarding my new Passat and the activation of TSP. I have now had the tow bar fitted and the dealer has confirmed that TSP has been activated in my vehicle when towing. The car needs a software download to activate it and therefore it is available in post fitment towbars as well as factory spec'd cars. I presume this will be the case in other cars with the ESP+ system??
946
Sounds realistic, yes. I can't imagine that any additional hardware would be necessary as this would only increase the number of components on the production line, something which manufacturers try to avoid if at all possible.
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
SGDRGH
