Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
It should have Electronic Stability Programme (ESP) which has a degree of traction control incorportated. But if it didn't I wouldn't be too bothered. I tow with a 2.0 C Max tdci (non DPF)(136 bhp)and it's excellent. My van is a bit lighter than yours (Ranger GT60), but it pulls as if there is nothing behind!
From memory C-max's got std ESP from 08 my. Under normal circumstances you will not need ESP, but it will not hinder. The traction control part will reduce wheelspin, but with a little restraint when pulling away, you should be OK.
To add to my post as you are still looking for a car, if I was buying a car to tow, I would look for a car with ESP. In my mind you can't have too many safety devices. You should not drive relying on them to save you though as they are still restricted by the laws of physics!!
As long as you have the towbar fully wired up then the Oylmpus has ATC trailer control which is a basic ESP for caravans.
There seems to be some confusion here between Traction Control and ESP. Although both use the same sensing devices at the wheels, they work in a totally different manner. Traction Control operates from standstill and cuts engine power when the driven axle loses traction whereas ESP compares wheel speed with vehicle speed and acts on the brakes if the two don't reconcile.
