Truma AC Remote
Jul 23, 2021
Hi Folks,
My Truma Saphir IR AC remote is broken, i'm waitng for the replacment to be delivered but it's going to be 2 weeks - Is there anything I can use as a temp solution.
If it was a household AC unit (GE, Panasonic, etc) I could download a universal android AC Infrared remote - but none of them seem to list Truma as a manufacturer? I'm hoping that Truma uses the same remotes as a household manufacturer but I don't know which.
Any suggestions?
An overheating caravan dweller.
2,695
Wow, just looked, good news, free delivery and they have 3. Down side, £250 each.
How cold are you!
Does is not have manual controls?
Amazon do some universal A/C controls. Perhaps researching the manufacturers might help. One for One
250???? That is complete robbery. I've already ordered a replacement direct from Truma for about €120 - won't get here for a couple of weeks however.
It's between 25 & 30 degrees where I am - very sweaty during the day.
So I just spent the past few hours going through every model from every maker ( the android apps have a profile for each ) & & I found the one I was looking for :)
So turns out the Truma Saphir uses the same IR profile as one of the Electrolux models.
i'm right now standing with my face in a blast of cold air.
Reactions: Jcloughie
5,307
We have the Truma Aventa Comfort. I wonder if the same app will operate it? Would you mind identifying the app and I will try it the next time we are away. Thanks.
Jul 23, 2021
Sure, the Amdroid app I used is called Smart AC Remote - All AC Universal Remote Control. Your phone needs to have an IR port for it to work - Older Androids have them but they are becoming less common.
Once you run the app choose Electrolux as the manufacturer - the app then gets you to test each profile.
For mine the 3rd profile worked. It doesn't have all of the remote options though, the ones that worked were on/off, temp+/-, FanSpeed+/- , Those are all I need really.
I'd be curious to see if yours works too.
5,307
Thanks downloaded it. Now to remember in 2 weeks time when we go out that I have downloaded it. LOL!
4,603
As in a previous thread I started, I am a App phobic, When a button or swith can be used why not, Blue teeth, Yellow fangs whatever, I hate them, for a TV maybe, or as Mrs H comes back from the Loo,
Bye the way Darling can you get me another cider from the fridge "Please"
Jul 29, 2019
36
9
10,535
Hi Folks,
Any suggestions?
we also have this unit fitted but I am unhappy in that the sleep mode does not make any difference to the noise level than the slow speed on the remote. Does your sleep mode make a difference in noise level. I know it does not effect the compressor noise. Not sure if this is normal or a fault on my unit.
