Hi there,
Wondering if anyone has an answer to the following…
Just put our leisure battery back in our van after the winter (it has been trickle charging through the winter in our utility room) and all looked good, everything else seems to be working as it should, although haven't switched any gas on yet, or run any water through the system after being drained for the winter.
However, when the main power switch is set to OFF (no hook-up, just Leisure battery), I get a warning on the Control Panel (W255 H). If I switch the main power switch ON (no hook-up, just Leisure battery), the error goes away. The manual points out the below info.:-
I don't recall this error showing previously, so just wondered if anyone else has encountered this error? If so, what was the solution?
Thanks in advance for any pointers
Cheers,
Craig
Furnace has no 12 VDC power supply. Ensure 12 VDC power supply. No connection between the furnace and the control panel. Ensure connection between furnace and control panel. Control panel cable defective. Contact Truma Service.
Cheers,
Craig
