Truma Combi 6
40
Related to my recent postings about avoiding tripping site supply. Considering a change of caravan to one which has Combi 6 heating for both space and water. User instructions on line I find confusing bearing in mind most of my use is in Europe including winter on sites with 6 amp supply.
One reading of the 'winter' use is that if on gas and water at the same time it will seek to maximise the energy input. Therefore would connect high wattage electrical heater as well as gas which would probably trip the site supply.
Can anyone who has Combi 6 tell me if they have used it on a site with limited supply e.g. 6 amps in these conditions and whether it is possible through the control panel to prevent the heater connecting the higher power electrical element. I did ask some time ago about the warm up time, but realise now that the favourable answers may have been related to sites with 10 amp supply or better in UK
4,327
Hello Ray,
Combi B booklet contains this instruction:
Check whether the power supply fuse protection at the camp site is adequate for the 900 W (3.9 A) or 1800 W (7.8 A) that have been selected using the power selector switch.
Hope this helps.
Mar 6, 2013
9
Following above you have 2 levels of electric to select, therefore level i would be your choice, the system will maximise at that level of electric and top up when necessary with gas.
4,543
We dont have the combi 6 but our combi in the coachman has 4 different setting gas Electric, Gas and 4 amp electris and Gas 8 Amp ellectric. So no problems on 6 Amp , in Europe.
