Getting ready today for first outing in recently bought 2007 Adria Adora 532UP SE.
When I connected the water supply everything seemed OK - water began flowing within 15 seconds of opening kitchen tap, however I noticed the pump was still running after a few minutes then realised that water was running under the caravan - this was traced to the heater drain valve being left open, valve was closed and aqua roll (now emty) was refilled and connected - similar problem was experienced ie water running under caravan - this time traced to the heater outlet valve breather line.
Water would not stop despite pump being switched off and on a few times - any advice welcome - going away this weekend.
Previous owner says no previous problem - just plugged in and water on demand
System is a pressure switch, not micro switched
Brian
Brian
