Truma heater element
3,547
All the models you mention are gas powered heaters using a cast aluminium heat exchanger.
The S3002 and S3002p each use one exchanger and are identical except the S3002 has a battery powered auto reignition unit to ignite the gas, where as the "p" suffix means it has a manual push button Piezo ignitor.
The S5002 uses two heat exchangers that are permanently fixed together with two burners to virtually double the heat output. It also uses the battery powered auto reignition unit.
The element you have is actually a Truma Ultraheat and is technically a separate product option that has to be used with one of the above gas heaters.
All the models yu mention are gas powered heaters using a cast aluminium heat exchanger.
The S3002 and s3002p each use on exchanger and are identical except the s3002 has a battery powered auto reignition unit to ignite the gas, where as the "p" suffix means it has a manual pushbutton Piezo ignitor.
Thanks for explaining that.
3,547
199
19,235
jondogoescaravanning.com
I have sourced a new element for my caravan heater,
Before you can fit the new heater element, the gas must be turned off and disconnected from under the caravan. Then the flue pipe needs disconnecting from the heat exchanger and the heat exchanger removed. It is essential that a new gasket is fitted before refitting the flue pipe. Finally, on safety grounds, pressure test the entire gas system and check that the CO detector is functioning.
