Truma Inlet hose
Dec 12, 2015
55
Has any one removed the blue float/ filter from the bottom of the pistol type hose, if so what did you replace it with ? I need something smaller to fit into as smaller opening than the 40l aquaroll .
Sep 4, 2011
714
435
19,135
Yes always take them off and just fit a non return valve. Stops getting air in system every time you take it out of aquaroll as the pipe stays filled with water,
Reactions: Devonboy
Dec 12, 2015
55
Thanks for your reply , take it you don't bother with a filter ? Is the barbed end of valve 10mm ?
Sep 4, 2011
714
435
19,135
Non return valve i use is not barbed but just use a stainless steel jubilee clip on pipe to hold tight..Haven't used the strainers for over 15 years.
Reactions: Devonboy
