Hello 🙂
I've been having trouble with my truma ultraheat on 240v I've stripped it down I have no green light on the control switch when turn in any position. I've replaced my pcb still nothing I have bypassed the 2 thermostats by temporarily placing wire between them and cutting them out still nothing.
I have 238v at the element wiring going into the element I used a working kettle element and wired it up to my element to see if that worked to see if my element was dead. I'm getting just over 50ohms of resistance on my element which from what I've read means it's good.
My father has the same van I pinched his control switch to see if it was that still no green light I'm now thinking it may be the umbilical core wire which runs from the 12v side of the pcb to the back of the control switch with the green light I have checked every wire for continuity and they all seem fine. I did last night get the green light when turned on for about a second then it faded out I'm wondering if ones of the wires on this umbilical cord is failing under load.
Any help would be appreciated I'm going round in circles 🙈
