Truma Ultraheat Fire - Heater Element Replacement
May 23, 2020
5
Hello
I have stripped down the fire to replace the heater element. Does anyone know how I remove the wires from the connector connected to the PCB board please.
Many thanks
Shelley
2,570
Welcome to the forum Shelley (Why dont you google Truma Ultraheat they have downloads for instalation and instructions ..
5,311
Does this diagram help you? The elements are very expensive , nearly £300. Hope you get the wiring correct. Having gone as far as you have may I suggest you also change the two TODs.
Reactions: Beachball
937
One question I have is how have you decided that the elements are at fault?
It is very unusual for them to fail (although they can do).
The usual suspects for the heater not working are the TOD's (one or both), or the PCB .
May 23, 2020
5
Thank you for your replies. I have managed to get the wires off. It was an auto electrician who my husband uses at his garage who has diagnosed it as been the possible fault!
937
Thank you for that info.
I hope all goes well and that you cure the problem.
May 23, 2020
5
TODs is that the temperature sensors located at the front? Will replace them as well and hopefully fingers crossed that will fix the problem. If not it looks like it could be the PCB.
Many thanks
5,311
There are two. Known as Thermal Overload Devices. One cuts out at 175deg c, and does not reset. the other cuts out at 125 deg c but as it cools resets.
Apuljack sell them at good prices. See the diagram I posted , parts noted as 21 &22. It is unusual for both main elements to fail simultaneously. Did the garage chap check the continuity of both elements? Hope you get it working.
May 23, 2020
5
No he didn't! Could be £80 wasted for the part. For what the TODs cost will replace them as well. Could end up been cheaper buying a new fire lol.
Many thanks for your help.
5,311
Shelley,
I have to ask, before the Prof does, have you removed the entire fire from the caravan including the flue and gas connection? Both are safety critical connections one requiring a new seal on each disconnection. Incorrect fitting wi cause a potential gas explosion and or carbon monoxide entering the caravan!
Nov 11, 2023
Hi. Sorry this is an old thread but joined the group. I have the same problem with no heat at any setting. I have power coming out the board so I'm guessing it will be the TOD,s. These are situated behind the gas section. How do you get to them or do you need to remove the gas section?
Stu
5,311
Stu
Depending on make and model you may be able to access the rear of the heater. Otherwise the while unit, section by section needs removing . It involves gas and flue joints and is not something to be attempted by an unqualified person. Note the flue gasket MUST be replaced with new.
Nov 11, 2023
Thanks for reply. I thought that might be the case. Think I will get them changed on the service to be on the safe side.
Aug 12, 2023
662
305
2,135
Before replacing elements measure their resistance NB they are just one big resistor that runs hot. I'm going guess resistance is 100s ohms. If open circuit >1Mohm then probably faulty. Just make sure there aren't any thermal fuses in circuit that your've overlooked, should be obvious once you've remove element.
Measure element again once it is out as other components in circuit can affect resistance reading.
5,311
The TODs are the thermal overload fuses!
Aug 12, 2023
662
305
2,135
These will be close to elements blow if temperature gets to high. Typically because heater outlet is blocked or fan has stopped in case if forced air heater.
5,311
The two TODs are different. One cuts out at 125deg C cools and resets. The other permanently cuts out at 175degs C. It does not reset
46
19,185
175deg stat does reset but its what's known as a 'self hold', when it trips it has an internal element that is connected that keeps it off until 240v is disconnected from heater, the stat itself can then cool down and resets automatically.
Reactions: RogerL and Dustydog
5,311
Didn’t know that Gary. Amazing what we get taught word of mouth! Thankyou👏👏
Reactions: gary
46
19,185
The other point I should have made is the 175deg is actually a fail safe, so the need to operate means the 125deg didn't and therefore it's that one that's faulty.
Overall though neither should be required to operate but using gas and electric together without enough fan speed to disperse the extra heat effectively is common reason. So it's essential while using gas with electric, that fan control is set at 'A' (auto) with maximum speed set on dial.
4,323
Also problems can arise if the fan has become clogged with dust and hairs, or if the hot air outlets are closed or blocked.
Reactions: gary
